120-140 speedo to fit 79 gt cluster
Discussion in 'Ranchero Parts Wanted' started by rancheromac, Aug 15, 2018.
  1. rancheromac
    rancheromac In Third Gear
    or other makes or years that would fit thanks
  2. 72GTVA
    You can put the factory Police 140 MPH speedometer from any '77-79 intermediate Ford. They didn't make a GT cluster speedometer in anything other than the "sporty 85 MPH" unit. The police unit will fit and attach as the original with the exception that the trip odometer reset button will be over the odometer. Check out post #4 in the gauge clusters and wiring thread here:
    http://www.ranchero.us/forum/index.php?threads/72-79-gauge-clusters-and-wiring.5005/
    The 74-76 120 MPH GT Speedometer will work but the gauge face style is different.
    I don't have any spares on hand. Perhaps Green Sales if they are still around.
    rancheromac likes this.
  3. euroman1a
    euroman1a In First Gear
    Winnipeg Canada
    rancheromac,are you still looking for a 12o mph speedometer?i've got an instrument cluster from a 1978 Ranchero parts car.
  4. Lee bear
    Lee bear In Second Gear
    Kingman Az
    I have some also
  5. 5.0 Chero
    sorry no stock 120mph speedos for 77/9
  6. euroman1a
    Winnipeg Canada
    78 instr.jpg It is from a canadian Ranchero
  7. 72GTVA
    GT Cluster from 1974 through 1976
    euroman1a likes this.
  8. Jeff B
    I have never been there but doesn't Canada use kmph rather than mph?
    andrewok1 likes this.
  9. andrewok1
    yea ,thats what i always understood as well
  10. euroman1a
    Winnipeg Canada
    ok,good to know that it is for an 1974 to 1976 but i took it of of a 1978 and for me it looked stock.point is it still will fit a 78/79 dash.
  11. euroman1a
    Winnipeg Canada
    Canada was in mph first but began implementing metrication in 1970,by september 1977 all signs were changed over to kmh
  12. 72GTVA
    It would be unusual for it to be original to the car. The 74 - 76 cluster with slight adjustments to either the 14 pin connector or a swap of the printed circuit could be made to work with the 77-79 cars. I would offer the opinion that a prior owner was not entirely enchanted with the 85 MPH speedometer or had an issue with the original cluster and made the change. A fairly complete discussion of the clusters available across the mid-size-full framed cars is here:
  13. euroman1a
    Winnipeg Canada
    well,after checking the link it turns out the printed circuit is the 74-76.
    thanks for the link.
    well,after checking the discussion it turns out the printed circuit is the 74-76,all the gauges but the clock worked in the 78 when i got the car and test drove it.again,that's why i thought they were stock 78.i can't check anymore what the previous did to the connector since i didn't take the harness out and the car is long gone.
  14. 72GTVA
    If you look on the back of the cluster, the printed circuit will have a number on it starting with D4, D5 or D6 - that will indicate the group from which the cluster originated.
  15. euroman1a
    Winnipeg Canada
