1958 in Las Vegas
Discussion in 'New Member Welcome Center' started by Friarfan, Jul 14, 2023.
  1. Friarfan
    Friarfan In First Gear
    Henderson, NV
    I have rebuilt a couple Mustangs (‘65 and ‘66) but this is my first venture in to a car older than mid-60’s and my first Ranchero. I’m in love with the car and very much looking forward to digging in to it and making improvements. It currently runs ok but there’s a lot of work on the interior (wipers, radio, clock, temp gauge, etc don’t work) and the workmanship on the finish leaves a lot to be desired. Hoping to lean on the experts in this forum for some education and help!
    first lesson I’ll need is how to upload pictures to this forum. Lol
  2. Clark
    SyrFish likes this.
  3. Friarfan
    Henderson, NV
  4. Friarfan
    Henderson, NV
  5. Clark
    Aw yes. Very nice. Been a long time since I've seen a '58.
    Looks like the original Y-block has been replaced. Great place for a 460 or even a 427 (if you have the $$).
  6. LSChero
    Nice! Welcome to the site.
  7. Friarfan
    Henderson, NV
    Yeah, originally had a 352 in it but I took it over with this 390 in it. It’s got a 4 barrel edelbrock carb, streetmaster 390 intake, exhaust manifolds, cherry bomb mufflers, and a points distributor. Plan on immediately doing the following;
    Install seatbelts
    Install wiring harness
    Pertronix distributor/ignition/wires
    Fix temp gauge
    Plugs/oil change
    Radiator flush
    Spacer on carb
    Upgraded fan blade
    Fan shroud
    Fix rear view mirror (very loose)
    Fix Window regulators and install glass
    Sooner rather than later
    Front disc brakes
    Replace suspension/body bushings
    Wiper motor
    Antenna/Radio
  8. Clark
    Well dang. I think Gear Heads Cruiser Products is gone but I see that Fabulous Fords (fabulousfords.com) still has plenty of custom products for '57-'64 Fords.
  9. Friarfan
    Henderson, NV
    That's a great source thank you! I've been struggling to find any decent suppliers and that one looks like the best one out there for original stuff.
  10. PonyExpressRider
    Check Detroit Iron Information Systems for manuals. I used the digital manuals, the part numbers in the assembly diagrams were also used by National Parts Depot. Made it easy to cross reference from other models. If needed.
  11. Friarfan
    Henderson, NV
    Ordered my USB drive full of info tonight. Thanks for the tip!
