1958 ranchero radio
Discussion in 'General Ranchero Help' started by Lorm, May 14, 2018.
  1. Lorm
    Lorm In First Gear
    How does the speaker 6x9 plug in ?
    andrewok1 likes this.
  2. Hillbilly
    Two little male pins on a bakelite strip. One pin larger than the other. High tech for back then.
  3. Lorm
    Lorm In First Gear
    Please explain or can you send pic of this item or a link , thanks
    On the speaker wires there is a plastic piece with two metal prongs sticking out (male X 2).
    On the radio there is a place where that plugs in (female X 2).
    These kinds of group male/female connections are common in electrical. Those of us in the trade are not responsible for the kinky things we have to work with.
  5. PonyExpressRider
    PonyExpressRider In Overdrive
    older speakers the posts will be parallel to each other.. newer ones maybe like pictured
  6. Lorm
    Lorm In First Gear
    Ok what I mean is on the radio side of things . Where do u connect the dash mount 6x9 ? Where on the radio ?
  7. Hillbilly
    It can vary by radio manufacture but the spot you plug in the two pins is normally directly on the rear of the unit, close to the antenna cable receptacle. Don't have one out for a photo, sorry.
  8. Lorm
    Lorm In First Gear
    Thanks I will post a picture later, where can I buy this plug ?
  9. Hillbilly
    Short of luckily finding one in an older car, I would hunt for an established radio or TV repair shop who has been in business for decades. Maybe look in "Hemmings" magazine for a dedicated older radio repair shop.
  10. andrewok1
  11. Lorm
    Lorm In First Gear
    I will check this evening
  12. andrewok1
    they may have what your looking for Good Luck
  13. Lorm
    Lorm In First Gear
    Ugh I need this plug I will try and post pics or a model Number of radio
  14. Lorm
    Lorm In First Gear
    One wire (fused) on side is for "acc" when key is on , other is for illumination ,then where does ground go ???? Post on back of radio ? Lost
  15. ribald1
    Best to connect the ground to the firewall ground point.
  16. Lorm
    Lorm In First Gear
  17. Hillbilly
    Is no separate ground on my 58 or 59. The radio chassis is grounded at the mounting points to the dash. This is before plastic dash crap, both control studs and the strap on the back anchor to the metal dash. The speaker is the only part with a separate hot and ground wire in that two pin plug. Simplicity.
  18. Lorm
    Lorm In First Gear
    Ok great info - I have a plug coming in the mail with zero wires after the pin , best way to modify this? Or do you know what pin is what?
  19. Hillbilly
    Solder wires to the pins. Pins should be hollow, insert stripped wire then solder them in. Big pin is speaker +, small pin is speaker -. I don't remember the ohm rating of the speaker but 8 ohm should work fine.
  20. Lorm
    Lorm In First Gear
    Thank you sir
