1964 Horn question?
Discussion in 'Ranchero Tech Help' started by tariko, Jan 10, 2010.
  1. tariko
    tariko In Second Gear
    Midland TX
    When I got my 64 ranchero, the horn ring was taken out and I can not tell what parts are missing. I am attaching 2 pics describing what I got and I am hoping someone could help me identify what's missing.
    Thanks.
  2. 72GTVA
    Best I can find - this is a '65 but it won't be much different. NPD Mustang has most of the parts. All that I can tell from your picture for certain is you are missing the spring but you could also be missing a contactor and some other parts.
  3. 5.0 Chero
    http://www.falconparts.com/search_r...earch=fromSearch&btnSearch.x=9&btnSearch.y=12
    http://www.falconparts.com/1960-1965+HORN+BUTTON+SPRING.html
    Category: HORN PARTS
    Product ID: C0DZ-13A807-B
    Description: This spring fits between the horn ring or button and the steering wheel and is required to keep the ring/button in place. Falcon
    Price: $4.00
    http://www.falconparts.com/1960-1964+HORN+RING+RETAINER.html
    Product ID: C2DZ-13A809-A
    Description: This Ford Falcon part is the retainer that holds the horn ring or button onto the steering wheel. It will fit all 1960 - 1964 Ford Falcons as well as most other Ford products of the same era.
    Price: $3.00
    Product ID: C5ZZ-13A821
    Description: This 1965 part is a horn contact kit consisting all new parts to fit into the horn ring of the 1965 Falcon ONLY.
    Price: $10.95
    http://www.falconparts.com/1965+HORN+RING+RETAINER.html
  4. tariko
    Midland TX
    Hey guys, thanks for the info. I guess it's clear that I am gona need the white ring retainer and the spring. Do you guys know what goes into the 2 threaded holes close the steering wheel nut and the black hole at the bottom?
  5. 5.0 Chero
    The two threaded holes are for a steering wheel puller
  6. George Zinn
    George Zinn In Third Gear
    From your picture looks like you need the "Horn Brush" (13A821). If so, Dearborn and others have them.
  7. tariko
    Midland TX
    Hi guys, thanks for all the replys.
    With all what you guys described below I figured i will need the plastic ring retainer, the spring and the brush assy. Am I missing anything? Is the spring supposed to connect the ground from the coloumn to the metal plate on the ring (sitting on top of the plastic retainer) so that when the horn button is pushed down, the metal in the ring gets in contact with the brush and close the circuit of the relay? Please help me with this:(. This is all I get left to get a sticker on this thing and get it finally registered.
    Thanks.
  8. 72GTVA
    The spring's purpose is to hold the contact apart until you close the switch by pushing on the horn ring. It "floats" under the horn ring over the steering wheel nut.
  9. drlance
    drlance In Fourth Gear
    Robinson, IL
    I'm gonna make a quick comment.... Wouldn't a Grant or Lecarra swap be a lot easier and faster?
    I swapped a Lecarra wheel onto my 79, It took longer to remove the stock stuff than to install the new wheel and horn button.
    Just my thought......
    Lance
  10. davis
    davis In Maximum Overdrive
    LB, CA
    horn
    if you need some time, you can pick up a horn button assembly at the Help! section of most auto supply stores. you'd have to rig the wiring and clamp it to the column, but it could get you thru the DMV headaches. my 2 cents.
    you're almost done with the "correct" install though, good job.
  11. tariko
    Midland TX
    I ordered the parts yesterday and the package is on it's way. Hopefully everything works out.
    About the swap, I left that as plan B if i couldn't find the parts but thanks to you all, I think I ve located everything I need.
  12. tariko
    Midland TX
    I got the parts and everything worked out well. I had to replace the relay too and I found out that the 2 horns were not working, I opened em up and found that the left one was still good and it just needed some cleaning hwever the one on the right was burnt. I guess one is better than nothing for now and should be enough to get me thru the state inspection.:D
    Thanks again for the help.
  13. Charlie63
    Charlie63 In Third Gear
    Asheville, NC
    63 Steering Shaft
    I have tried numerous times to get my steering wheel together per the parts breakdown that was posted earlier.
    My son pulled the shaft out, and we found a Ford sticker on it, so we guessed that it was replaced sometime in the past.
    If anybody has the steering apart, could you measure the length of the shaft? Maybe the replacement shaft wasn't for a 63.
  14. Charlie63
    Asheville, NC
    If the information in the AutoKrafter's catalog is correct, 60-63 has a 40" input shaft, and 64-65 has a 39" input shaft to the steering gear box. That maybe my problem as to not having enough shaft to get the horn installed.
  15. dadcohn
    dadcohn In Second Gear
    Danville, CA
    I am also trying to get the horns on my 64 to sound. I tested both horns directly from the battery and both sound (one much better than the other). Then I unplugged them and pushed my test light into the plug on each and pushed the horn button and neither lit up. However when I unplugged the plug from the relay and put the test light into the plug it did light up. Does this mean my horn relay is dead and causing the problem?
  16. 5.0 Chero
    yes its a sign the horn relay may be bad but you need more testing
    pin out for relay
    3 should be hot all the time
    1 should be hot when horn ring is pushed
    5 is ground signal from horn ring when pushed
    to test horn relay with it plugged in ground out terminal 5 with a jumper lead
    horn sounds - the problem is before the relay
    no horn sounding need more testing
    hook test light to terminal 1 repeat test
    no light bad relay
    if test light lights problem is in wiring from relay to horn
    Freestyle Don likes this.
  17. Doc76251
    Doc76251 In Fourth Gear
    Virginia Beach, VA
    So what did you do with the stock steering wheel:D
    Cheers,
    Doc
  18. 5.0 Chero
    Doc that post was in 2010 he has not been on since 2017 I may have a stock wheel if you need one
    Doc76251 likes this.
  19. Doc76251
    Virginia Beach, VA
    Hey THANKS 5.0!! I'm not sure if I want to go back to original but I've got this 13" Grant "thing" that just doesn't suit my hands (or the car IMHO) and I remember the one from my T-bird and never had to look around it to see the gauges. I'm really enamored with the OEM "sport" wheel with the wood grip a'la the Cobra but would like to find it with black metal. Half looking for an OEM black one on a tilt column. I'm still up in the air about what to do with the interior tho. I'm kinda waiting to pull the trigger on a 408 stroker build and a T-56 Magnum which will require the floor to change more than a little before I get serious about the inside, but that Grant wheel is killing me.
    Cheers,
    Doc
  20. dadcohn
    Danville, CA
    5.0....I ran the test on the horn relay. When I grounded out #5 nothing happened. When I then touched #1 with my test light it lit up AND honked. Does that indicate bad wiring AND a bad relay?
