1967 500 - Buster - Main Restoration Thread
Discussion in 'The Stable' started by eqshadimar, Mar 7, 2006.
  1. As Is '66
    Southwest Georgia
    Progress!!!
    You GO Boy!!!
  2. desertdale
    desertdale In Overdrive
    Darfield, UK
    That motor is a thing of beauty.......
    Excellent work, Well Done......
    Glad it'a all worked out ok.
  3. eqshadimar
    eqshadimar In Overdrive
    Austin - TX
    Thanks for the comments. I am going to try and take some pictures this weekend in the sunlight. I want to make sure that all the people who read this thread have new stuff to look at [​IMG]
    Laters,
    Jeff
  4. eqshadimar
    Austin - TX
    Long bump to the top. I posted some updates in the first post. As promised here are some pictures I took at the seller's house when I first purchased Buster:
  5. ForistellFord
    Beautiful Foristell Missouri
    What a beautiful 67.
  6. eqshadimar
    Austin - TX
    Some internal engine pictures. It is a 347 stroker motor with all the goodies:
    More later on in the thread
    Laters,
    Jeff
  7. eqshadimar
    Austin - TX
    Some additional engine swap pictures:
    Laters,
    Jeff
  8. eqshadimar
    Austin - TX
    Last of the pictures for now :) Front suspension repair:
    Phew ok I think that is the majority of the pictures from all my old threads. As I mentioned I have a couple of upgrades in the works so watch this space.
    Laters,
    Jeff
  9. parts4me
    parts4me In Maximum Overdrive
    Nebraska
    Looking good! Great engine swap!
  10. davis
    davis In Maximum Overdrive
    Whittier, CA
    looks great.
    a good time to paint your master cylinder.
    that 347 looks tough, neck-snapper over that 2V!
  11. Hillbilly
    Doin' it nice takes lot's of time even when everything goes your way. Looking great Jeff ! Got one dummy question fer ya though. Why did the previous owner feel the need for a block heater ?
  12. ribald1
    What heads are you using?
  13. eqshadimar
    Austin - TX
    Haha good eyes! Originally the truck was in Colorado so the block heater was probably needed there. I didn't put it back on for here in TX :)
    Laters,
    Jeff
  14. eqshadimar
    Austin - TX
    Here is probably more information than you needed or wanted but what the heck:
    347 Stroker Motor –
    9.5:1 Compression Ratio, Eagle Forged Rods, Probe Flat Top Pistons (machined for valve clearance), RPM Main Bolt Girdle, Crane Hardened Pushrods, New 5.0 Roller Cam Block from SVO, Custom Lunati Cam, Brass Freeze Plugs, SVO Double Roller Fully Indexable Timing Chain, SVO "FluidDampr" Style Harmonic Balancer, Canton 7 Qt. Oil Pan, All ARP Hardware, March Chrome Kit (pulleys, alternator, A/C compressor, etc.),Taylor 8MM Custom Fit Wires, Stage 3 ported and polished Dart/World Products/World Castings/BMP (phew :) ) “Windsor Jr.” style heads (with Manley Valves, Triple Valve Springs, SVO 1.6 Roller Rockers, and SVO tall aluminum valve covers), ported and port matched Victor Jr. Intake, a Chuck Nuytten Holley 4150 750 CFM Double Pumper, K&N air cleaner with flow through S&B Filter Top
    Transmission –
    Manually shifted C4 prepped by Performance Automatics, street/strip HD converter, B&M Pro Stick Shifter
    Ignition-
    MSD Blaster Coil, MSD Billet Distributor, MSD Digital 6 Plus
    Fuel System –
    Mallory 200 GPH Fuel Filter, Holley Blue Electric Fuel Pump, Regulator, Stainless Steel Braided Hose from the Gas Tank to Carburetor with Aeroquip Fittings everywhere
    Laters,
    Jeff
  15. DonC
    Gonzales Louisiana
    Ought to run sweet, nice setup.
  16. ribald1
    Always want to know the full build.
    Didn't recognize the World heads, they looked a bit like the Dart Pro, but not quite.
  17. 74Rancherito
    74Rancherito In Fourth Gear
    South Central, Cali
    Beautiful setup!
    That thing's gonna run like a scalded dog....
    Great work.
  18. eqshadimar
    Austin - TX
    Thanks everyone! I have found some additional pictures so here ya go:
    Oh I also edited one post earlier in the thread to show better pictures of the internal brace since I got a PM about it.
    Laters,
    Jeff
  19. eqshadimar
    Austin - TX
    More pictures:
    Laters,
    Jeff
  20. eqshadimar
    Austin - TX
    Last ones for today:
    and this is some not good news I discovered last night. This is the radiator tube:
    Have to think on this one for a bit.....
    Laters,
    Jeff
