1969 door glass run question
Discussion in 'Ranchero Tech Help' started by Car Nut, Jul 26, 2020.
  1. Car Nut
    Car Nut In Second Gear
    Lake Tapps .Wa.
    My door glass saga continues . Ok so there are 2 runs in each door for . (the round bar that the door windows roll up and down on ) 2 of them have the bar welded all the way back on the bottom where you bolt them down on the bottom of the door . the other 2 have about 1/2 in of the bottom plate behind the round part . They have no good id on them to go by the manual .
    does anyone know which is the front run and which is the back run?
  2. PonyExpressRider
    I don't remember there being a difference... but maybe this diagram will help, as well as the adjustment procedure.
  3. Car Nut
    Lake Tapps .Wa.
    thanks for the info , I have all that . Has you can see in the diagram there are 2 distinct part numbers for the Runs. Of coarse they have no part numbers on them . And that diagram does not show a good closeup of the bottoms of each.
  4. Dyno
    Dyno In Fourth Gear
    Croydon, Pa
    Just a thought but the round tubes should have a wear line on them to help with front and rear ID. Bottoms should only bolt in one way then.
