1978 Ford Ranchero 302
Discussion in 'General Automotive Questions' started by kal, Oct 7, 2018.
  1. kal
    kal In Third Gear
    Charleston WV
    Needing to know what this piece is for? IMG_20181007_160722[1].jpg IMG_20181007_160647[1].jpg IMG_20181007_160722[1].jpg Have been told everything from oil filler to emissions part. It is on the exhaust manifold on the passenger side. The neck is attached to the exhaust manifold itself.
  2. 1965 Ranchero 66G
    Hard to tell, pics are pretty fuzzy and to close.
  3. aquartlow
    Isn't that for the "heat riser" tube for the air cleaner, basically a sheet metal shroud mounted/attached to the exhaust manifold.
  4. kal
    kal In Third Gear
    Charleston WV
    Not sure but what ever it is it has a crack in it. I know this is a factory A/C car & the A/C compressor is gone.
  5. beerbelly
    I agree with aquartlow- that's a heat riser tube to provide warmed air to the air cleaner/carburetor.
  6. kal
    kal In Third Gear
    Charleston WV
    ok thanks got that figured out now get it to were it is getting fire. Going to replace the ignition control module & spark plugs & ignition coil next see if that fixes the problem.
  7. kal
    kal In Third Gear
    Charleston WV
    Need to sell 78 Ranchero ASAP located in Charleston WV text 304 932 5942.
    Is there something that went wrong? I remember that you were itching to get her running.
  9. kal
    kal In Third Gear
    Charleston WV
    Had some stuff come up last resort was to sell car for the money need it gone ASAP.
