  1. 65restomod
    Now I understand why you need hub centric rings .
    I suppose it could be the drum shifting and lopsided then kinda centering its self again
    does the bearing fit snug in the tube?
    Do the drums fit kinda close to snug on the studs? If so that may rule out off center drum wobble
    did you try and swap tires and wheels front to back?
    Another thought is : there may be water , another liquid or a foreign object (believe me) in there which may account for the shake
    I've found shop rags, water and old bits of valve stems
    Just trying to help:)
