1978 Ranchero Parts
Discussion in 'Ranchero Parts For Sale' started by Bobby Bo, Jul 12, 2019 at 11:22 AM.
  1. Bobby Bo
    Bobby Bo In First Gear
    Pompano Beach, Fl
    Parts for sale from my 1978 351 m
    All old wiring connectors for car. Hard to find.
    Cooling Engine Fan, shroud, and used radiator
    Complete air cleaner set up.
    Original A/C compressor
    Original Belt ten tension set up
    Original Distributor with cap
    New Ford coil and wire connector
    New!! one two and one three connector electronic ignition spark control modules
    One good used electronic ignition spark control module
    One good user electronic ignition control module
    Rare to find good gauge cluster font clear plastic 2 pcs.
    Good used electronic ribbon and light sockets for the gauge cluster
    Good used Speedometer, oil, water, gas, and temp gauges
    NOS in dash heater / fan control module in the box
    Good used head light switch.
    Used a/c/condenser
    Used complete pollution control system with air pump, metal shrouds etc. ( for heavy correct restorers).
    Used manifold water neck for radiator hose with the two vacuum valves
    Various small connectors and brackets that are under dash.......
    One plastic Ranchero GT bezel that is mounted in the dash over the glove box.
    Call for needs with decent offers for all 954 971-1099 Bob
  2. Doc76251
    Doc76251 In Fourth Gear
    Virginia Beach, VA
    You wouldn't happen to have power windows in that car do you?
    Cheers,
    Doc
