Hello, I need help how the kickdown rod connects to the C6 transmission on the 78 Ranchero with the 400 engine. Car was taken apart for years and cant figure out how it goes back. I might missing a linkage or something. The shift cable also not sure. If someone can post a picture how it should look like it would be great. Thank You!
I just need someone from this community with a 78 Ranchero to take a picture of its levers on the transmission.....
you are missing a lever, this lever is then attached to a rod that is attached to your carb. i can't post a picture as i don't have a C4 however my 72 had a FMX when i bought it. i fitted a AOD then that was swopped for a 4R70W they all are hooked up to the same column shift cable shown in your picture. google will show you lots of pictures of your missing part attached to a C4 [ i just looked] and Lokar will sell you the part needed to hook it up. if that is missing.
