3G Pa Performance
Discussion in 'Ranchero Tech Reference & Articles' started by Dyno, Jul 16, 2022.
  1. Dyno
    Dyno In Overdrive
    Ridgely, MD
    Upgraded the alternator today among other things.
    Bought the 3G alternator 95 amp, their voltage regulator, wire harness and charge wire all from PA performance. Everything installs easily was able to use spacer and brackets with no adjustments needed. Clocking of alternator I left alone as that keeps wires in towards block not hanging out loose. Wire harness is plenty long for connections on alternator. The third wire needs connected to an ignition hot source I went to the solenoid ignition side.
    Changed the pulleys over from old alternator to new as they supply a single pulley and old one was a double pulley. Comparison pic on bench before change over. Fan does not swap over and you don't have many threads to grab on shaft to retain pulley. Air gun tight should hold .
    Installed upgraded charge wire due to amps per their recommendation. Note instructions give you a way around this if so desired, I don't like a lot of splicing in wires so went with theirs. The charge wire has a block that needs mounted with a 200 amp fuse in it, found a hole already in fender apron to use . Find your own screw to fit. Wish wire wasn't red but again that's a personal preference.
    There are ways to go cheaper already detailed on web, Pa does a lifetime warranty.
    Here's some pics that may or may not help.
    Charging at 14Volts now ! With fans and headlights on. 1gstart.jpg 1Gvs3g.jpg 3ginstalled.jpg 3gcomplete.jpg
    Which "solenoid hot side" did you use? IIRC, the old "A" terminal on the regulator connector is the ignition source you're supposed to hook to. I'll have to look it up later, but as I recall, the "A" terminal has either a fuse, or a fuse link, to protect the charge circuitry and alternator. Anyway, congratulations on an otherwise righteous install; just out of curiosity, what did you pay in total?
  3. Dyno
    Dyno In Overdrive
    Ridgely, MD
    Andy thanks. Yes side farthest away from power connections, the one that got eliminated in later years, not the one to bump starter. Yes there is a resistance of some style in it , however it stays hot while running. I have the MSD, relays for fans and now this alternator wire all triggered from this spot.
    Cost is about $300 shipped to door. Here's a link.
    https://www.paperformance.com/alternators/ford/mustang/65-85-mustang-all/
  4. Hillbilly
    That wire you tapped into is directly tied into the original coil power feed running thru the resistance wire in the dash harness. The coil normally ran on a slightly reduced voltage but utilized the wire on the "I" terminal of the solenoid to get a voltage bump to the coil while cranking. Think you will find that if you find a better trigger source without the resistance wire in play your alternator will produce more juice. That was the point of going 3-G, right ? You have an idiot light for the alternator in the dash ? Find that trigger wire in the original voltage regulator plug and use that. Been there, already smoked the cigars and wore out the T-Shirts.
    Dyno and 1965 Ranchero 66G like this.
    Only problem with the indicator wire, is that it'll illuminate the ALT light. But, I think I'm also wrong; I'm looking at a 1G alternator diagram, and the "A" terminal is connected to the charge wire at the BAT end, at a splice (or at least it is on the '79 diagrams). I don't have access to my '64-'68 book, which would have more accurate diagrams. The '68-'69 fuse block may or may not have one each BAT and IGN terminals; if it does, that IGN term is what needs to be hooked to.
  6. Hillbilly
    Andy, indicator light uses the alternator as a ground to complete the circuit and illuminate the lamp. As soon as the alternator spins enough to make current it sends current back toward the lamp. With current hitting the indicator lamp from both directions the lamp goes out.
    uk ranchero likes this.
  7. Dyno
    Dyno In Overdrive
    Ridgely, MD
    Hillbilly, thanks for the info. Forgot the reason I had stopped using that tap years ago. Timely reminder, will straighten out another day.
    That change shouldn't take long. At least it will work for the moment and actually charge old alt was done at 12v.
    Hillbilly likes this.
    Right. That's why I think it wouldn't work as a power source. But hey, stranger things have happened with electricals in our cars....
  9. Dyno
    Dyno In Overdrive
    Ridgely, MD
    Well today was going to go out to a show today but plans changed.
    So instead went to garage and rewired the 3G alt install. Looking at print and then finally at the short "destructions" included with alternator, you know the stuff a guy never reads !
    Well they state there you can use the old field wire (orange in my connector) to power the 12V signal that is needed. Checked with test light and it is key on in run and shuts off when not this is thru their regulator that is used when you change over. It is kind of a dummy regulator to keep charge light off and not really used otherwise is the understanding I get from it. Keeps the power flowing and that is what matters. Also covered some of the wiring while I was there.
    Used a .176 butt connector into old harness, ran that to power strip and hooked up "trigger" wire for Alt also electric fan relays. Pics attached. Charging at 14.2-14.4 with lights and fans on. AltRewire.jpg
    Good use of the terminal strips. Just make sure you have a splash guard down below to keep water off them.
