5.0 help, car won't run right after tune up
Discussion in 'Ranchero Tech Help' started by beefcake, Jun 2, 2004.
  1. beefcake
    beefcake In Second Gear
    cincinnati
    I'm editing this thread, so read the whole think please
    ok, i've got an strim on my 90 gt, it was running fine, but 1 of the belts were shredded and i figured might as well change and due a tune up.
    now, the car is falling on it's face,
    this is what i did,
    changed serpentine and s/c belt.
    cleaned and oiled k&n filter
    changed plugs wires cap and rotor
    now, instead of idling smooth, the engine falls on its face, it'll idle fine for a couple seconds after the car is started, but then the idle will start dropping down to almost nothing like the car is going to stall, and then it will all of a sudden come back up and spin and then almost stall and then spin,
    the closer it comes to stalling, the faster it spins and then falls on it's face again,
    i checked all the plugs and wires and where they are at, #1 is almost at noon on the distributor, i tried pulling the air filter in case i oiled it too much or something and wasn't getting air
    i also changed the battery, the battery all of a sudden was dead for no apparent reason, now the car will start and not stall but almost stall, when the battery was dead, and i was jumping it, it would stall.
    does anyone have any clue as to what the problem might be, the 5 year old crap had the car running great and now it's crap,
    i am 100% sure it's not the maf as i have run the car in default mode and it still does it
    the car runs fine for 20 seconds and then the idle starts dropping and then dropping more, etc...
    one of the mechanics at my dealership told me it's the plug gap, since i changed it to 35 it's probably having trouble, but i know for a s/c'd car you need the 35 gap
    edit
    i am thinking there is an underlying problem, and maybe this will shed some more light, today, i loosened the s/c belt as i was going to test that theory, i went to start the car and it cranked once and then died. there was no interior lights, no headlights notching. now, remember, b4 i did the tune up , the car was running fine and starting fine, after tune up, battery was pretty much dead,
    so, i get out the jumper cables and hook them up to my other car, right away i have interior light, go to start the car, starts right away. i shut it off, i unhook the cables and the light is still on, i go to start the car, it starts fine, very weird to me, a battery doesn't charge in 5 seconds.
    so, maybe this is relative to the other problem that i am having
    if n e 1 has some insight please lone it to me
    [ June 05, 2004: Message edited by: beefcake ]
  2. Rancherous
    Buffalo, NY
    Beef I would disconnect the battery for about an hour and let the computer reset and check for code errors.
  3. Rancherous
    Buffalo, NY
    clean the EGR and IAC? Cleaned the MAF? Run codes? This is what I found elsewhere.
  4. beefcake
    cincinnati
    put a new battery in since this was goin on
    no check engine lights
  5. Rancherous
    Buffalo, NY
    I sent you a link on a search and it really sounds like your IAC.
  6. 5.0 Chero
    Terry Check the IAC it bolted to the intake on the throttol body twoards the front of the cap if its sticking it will cause a surging Idle Also sounds like mine when I had a bad maf on it.
  7. beefcake
    cincinnati
    with the car in default mode, it is not running off the maf, i thought i put that in the first post lol,
    i was talking to my used car mechanic who races mustangs at the dealerships, i told him what was wrong, he asked me what my plugs were gapped at, i told him 35 per vortech, he said that right there is my huckleberry, he doesn't know where they got that #, but he said the car is not burning off enough fuel he said regap around 45 and all should be well
  8. Rancherous
    Buffalo, NY
    Beef that would make complete sense if it ran fine before the tune up.
  9. beefcake
    cincinnati
  10. 5.0 Chero
    Terry it has to be a bad conection some where! Maybe a bad cable end or bad ground!
  11. Dan the ranchero man
    I would be checking to see when you did that tune up if you damaged or unpluged a connector or wire. I would also look for a vacuum hose or connection that might have been knocked loose while working on the car. I would trace my steps back through and see if there was anything you might have done. I did the same thing on an 84 merc wagon. all tuned up and wouldn't run right to save a life! Found a hard plastic vacuum hose that had a small crack (I moved it to get at the plugs) Once replaced the car ran great again. Good luck Dan
  12. beefcake
    cincinnati
    <BLOCKQUOTE>quote:</font><HR>Originally posted by Dan the ranchero man:
    I would be checking to see when you did that tune up if you damaged or unpluged a connector or wire. I would also look for a vacuum hose or connection that might have been knocked loose while working on the car. I would trace my steps back through and see if there was anything you might have done. I did the same thing on an 84 merc wagon. all tuned up and wouldn't run right to save a life! Found a hard plastic vacuum hose that had a small crack (I moved it to get at the plugs) Once replaced the car ran great again. Good luck Dan<HR></BLOCKQUOTE>
    tomorrow i'm going to regap the plugs to stock gap and see if that fixes it, then i know for sure, i took it from 35 to 40 and i do think it's a tad better, but who knows
    tomorrow i'll know for sure, then it's off to checking sensors, my old mech who specializes in vortechs did tell me that the 5.0's did have trouble sometimes with the stock gap,
    i got an idle air spacer but i want to make sure that the plugs are the prob first
  13. beefcake
    cincinnati
    problem fixed after regapping the plugs to .52,
    so, now the question is, what needs to be done to get the car to run well at .35, the car may actually run well under throttle, but i haven't even tried,
    not to mention, i'm using stock plug, so once i go 1 heat range colder, problem will probably be even worse,
    also, since the plug gap definately is the prob, what exactly is the problem ?
  14. GregoryM
    GregoryM In Fourth Gear
    Federal Way, WA
    <BLOCKQUOTE>quote:</font><HR> problem fixed after regapping the plugs to .52 <HR></BLOCKQUOTE> Wow! That's over half an inch! Seriously, might the widening of the gap in effect, retard the igniton timing abit? Just a thought.
  15. rancherogt78
    rancherogt78 Guest
    If you don't have a boost reatrd, get one. Sounds like your ignition system needs to be upgraded to M.S.D. if you haven't already. The stock system often pukes with boost.
  16. beefcake
    cincinnati
    well, was a little more too it, last night, put in a new alternator, old one was bad, that combined with too low of an idle setting was killing the car at idle.
    after that, it was running good again, same as b4, but still falling on it's face at wot.
    put in the 24 autolites (1 heat range colder due to blower) and gapped them at 35 as was originally recommended, car is still running and idling right, now the big end death is gone and running awesome [​IMG]
