'61 144cid Engine mounts
Discussion in 'General Ranchero Help' started by bnorwood, Jun 24, 2022.
  1. bnorwood
    bnorwood In Third Gear
    All:
    Has anyone found one of these *recently*???
    I have searched at all of the usual suspects (Ecklers/Mac's, Rock Auto, Kanters, etc.) and NO ONE seems to have these in stock. The ones I need were only used 1960 and early into '61 production years. They have TWO bolts into the chassis:
    I am in desperate need of at least one (should do both) - or else I won't be able to go to the National meet in a few weeks!!!
    Thanks for any pointers/tips/help you can provide.
    Brad
  2. Jeff B
  3. beerbelly
    If you have an early Falcon or Ranchero, those are the go-to folks for parts.
  4. bnorwood
    They are out of stock at Falcon Parts....I had already checked there, too.
  5. 65ranchhand
    65ranchhand In First Gear
    Paige Texas
  6. bnorwood
    Out of stock at Summit, too (they don't tell you that until you're about to check out).
  7. Jeff B
    Checking with a local parts house and it's a maybe. Will know more on Monday. Will advise.
  8. Jeff B
    Sorry, no luck here either. For what it's worth, the part number is either 2170 or A2170. It was also suggested to find a service that custom makes mounts or will re-cast (rebuild) the broken rubber with urethane. Good luck.
  9. beerbelly
  10. beerbelly
