62 Progress Again
Discussion in 'The Stable' started by DonC, Nov 26, 2011.
  1. DonC
    Gonzales Louisiana
    Explorer 8.8 coming together, all new except for the housing and carrier. Shortened to 45.25 inches.
    Brackets for the upper triangulated 4 link made adjustable so I can change the anti squat from 30% to 130%.
  2. DonC
    Gonzales Louisiana
    Adjustable brackets installed and sheetmetal relieved and boxed in to fit house new upper control arms.
    Panel repair, panel made from 92 mustang door skin.
  3. ribald1
    Impressive!
    Why not a 9?
  4. DonC
    Gonzales Louisiana
    Rear and suspension installed for fit test.
    Suspension set-up for normal ride height.
    Wheel well extensions being welded in.
    Progress on extensions
    Frontend and bottom painted.
  5. DonC
    Gonzales Louisiana
    Hard to come by over here and I didn't have the patience to look for one. I sometimes wish I would have waited, just saw one in craigslist yesterday of course now that I don't need one.
  6. DonC
    Gonzales Louisiana
    Wheel well extensions welded and ground down.
    Extensions smoothed out and primed.
    Top view of modded well under bed cover.
    Rearview of car how it will sit.
  7. parts4me
    parts4me In Maximum Overdrive
    Nebraska
    Wow, that is looking good. Did you have to widen the wheel wells in the back to make room for those tires?
  8. Bryan59EC
    Bryan59EC In Overdrive
    San Antonio, Texas
    You'd best go back and look at the pics:D
  9. 74Rancherito
    74Rancherito In Fourth Gear
    South Central, Cali
    Wow Don!
    You do such a great job at fabrication....
    Very well done.....
  10. LSChero
    Looking good Don!Hows the power plant build coming along,would love to see pics.
  11. DonC
    Gonzales Louisiana
    Ah forgot about taking some shots of it, it's for the most part finished and is sitting in the chero. Have the headers on, intake system for the most part in place, still waiting on my ac compressor to get the belt in place. Still need to rig up an air filter box and get the computer wired up. Will get some pictures of it soon.
  12. DonC
    Gonzales Louisiana
    Yep, stock 62 frame rails go towards the outside of the car right around the front part of the wheel wells. No way to get the those tires in there without removing the old frame wells and installing some new homemade ones. Then widening up the wheel wells.
  13. billg72469
    billg72469 In Fourth Gear
    corona ca
    Didos with all of the hard work, what size of tires are you running front and rear? If I see the pics correctly are you only angling the upper arms?
  14. HuevosRanchero
    Fan-freaking-tastic dude!
  15. DonC
    Gonzales Louisiana
    The tires are 315/35/R17's in the rear with 11" rims 3" backspace, fronts 7x17 4.75" back space tires are 225/45/R17's.
    Yes I only made the uppers adjustable. I thought about having two holes on the bottom arms but decided against it and to just move the uppers for anti squat adjustment. Didn't want to have the lowers too long and hanging down too low.
  16. airford1
    airford1 In Maximum Overdrive
    OUT-OF-CONTROL!!!!! Too Cool...........
  17. 60To63Ranchero
    60To63Ranchero SITE SUPPORTER- GOLD
    Houston, Texas
    First-class fabrication work!
    This makes me feel like a slacker by comparison. I've had my '62 for seven weeks now and still trying to get through an engine rebuild and gas tank installation. I hope I can get it running by Christmas.
    Bob the Builder
  18. Kev250R
    Fullerton, So.Cal.
    Me too! My '60 has been parked for the past month because of over-heating issues. Great job Don C! You're giving the rest of us something to look-up to!
    Kevin
  19. dave r
    dave r In Second Gear
    Nice job Don. Tubbed yours a lot more then the 60 I'm doing. What front suspension are you using? I used the tci kit.
    Good luck, waiting for the finish.
    Dave
  20. Giska1
    Really impressiv work, what power plant are you putting in there. Anyway it's a awsome job youre performing:cool:
