62 Progress Update
Discussion in 'Ranchero Pics' started by DonC, Aug 18, 2011.
  1. DonC
    Gonzales Louisiana
  2. DonC
    Gonzales Louisiana
    AOD with 4R70W Internals
    Lentech valve body installed. This valve body gives a true 4 gear selection and overdrive lockout switch.
    8.8 with tubes cut making total axle width of 45.25 inches to fit the new 11 inch rims with 12 inch tires and 3 inch backspacing.
  3. DonC
    Gonzales Louisiana
    347 with comp cam XE282HR, AFR 185 heads, Edelbrock Performer II intake, flat top forged pistons.
  4. DonC
    Gonzales Louisiana
  5. LSChero
    Nice work Don!What stroker kit did you decide on?We need video of start-up!
  6. turborscapri1984
    turborscapri1984 In Second Gear
  7. bscottie
    man I like seeing this kind of work
    looks great!
  8. parts4me
    parts4me In Maximum Overdrive
    Nebraska
    Is that all gonna fit under that hood???!!:eek:
    I like the rims you have chosen. They look good with the red paintjob. Well done man!
  9. 74Rancherito
    74Rancherito In Fourth Gear
    South Central, Cali
    That thing is gonna be sick with those wide wheels....
    i have a 62' i bought about 10 years ago...
    runs great but needs tons of work...stock 144 with 2 speed
    How are you gonna stuff all that motor between the shock towers????:cool:
    awesome work!
  10. TestDummy
    True that! Don is going to have the first Ranchero here worth over $20K.
  11. HuevosRanchero
    awesome!...You truly are the new "Dandy Don" :D
  12. DonC
    Gonzales Louisiana
    It may be worth that or more in parts but no one is ever going to pay that much for a Ranchero We still love them anyway.
  13. DonC
    Gonzales Louisiana
    Got my kit from CHP, they had the best prices and broadest choices in my opinon. The crank is a scat cast steel crank and probe pistons forgot who the rods are from.
  14. DonC
    Gonzales Louisiana
    The motor sits low and the falcon/ranchero have quite a bit of room under the hood top to bottom, left and right well not so much.
  15. DonC
    Gonzales Louisiana
    Shock towers are gone, I installed a Heidts MII suspension so extra room now.
  16. 74Rancherito
    South Central, Cali
    very cool......that really opens up room .....
    kindof pricey......but wth......can't take it with you.......
  17. turborscapri1984
    Yeah thats what I thought at first too. I have almost enough money invested in rebuilding my front end and suspension to pay for a Mustang II swap. They really arent that much for what you get. ;)
  18. ribald1
    Good job Don!
    Looks like you will end up with a small displacement rig that will end up near the top of it's class.
    Lots of cubes can cover a lot of errors, or at least make people ignore them.
    Keep up the good work.
  19. 74Rancherito
    South Central, Cali
    you had better start a small fund for tires, cause that little thing is gonna be smokin' em.....
  20. steeread
    steeread Guest
    I'm sorry, but I was raised to believe that if you didn't have anything positive to say, then don't say it. So...I'm not saying.
