64 ranchero Tie rod ends question
Discussion in 'General Ranchero Help' started by tariko, Nov 22, 2017.
  1. tariko
    tariko In Second Gear
    Midland TX
    Does anyone know the part number for the tie rod ends on the 64 with the 4.3 engine ?
    any recommendations on where to find them will be appreciated.
    I have been searching for them locally and online and so far everything i got that was supposedly a fit ended up been different than the original ones in the car. the ones i am able to find are either bent to 1 side or have a smaller stud diameter.
  2. plumcolr
    Try rockauto.com, under ranchero, 4.3. steering, tie rod end
  3. plumcolr
    And a PS: almost all components on a 64 - 65 chero are the same as a Falcon station wagon or sedan delivery similarly equipped.
  4. tariko
    Midland TX
    thanks plumcolr, i actually looked at those but what they ve got listed as inners look very different than what came off mine. they don't provide any measurements neither. i emailed them to see if i can get any measurements of the rods and the studs but they just keep sending their generic reply stating that if it's listed for the car i am looking for it should fit. I will probably just order them and see if they re the same, that's the only way to tell for sure.
    here is a pic of what they list as inner.
  5. ribald1
    The pictures are often just a representative image.
    Cross check the part number, if the part number is correct get it, if it ends up being wrong they are very helpful with finding the correct part. you have to understand why they don't want to deal with every nervous customer, as that is all they would do all day.
    I have found that they are very good about dealing with issues with parts that have been purchased.
  6. tariko
    Midland TX
    good to know they re helpful. will give em a try and hopefully will get the right parts. I didn't anticipate the tie rod ends will be this much difficult to find. i am rebuilding the front end and was able to find everything else.
  7. Bryan59EC
    Bryan59EC In Overdrive
    San Antonio, Texas
    64 & 65 steering on the v8 cars is different------64 uses one set of parts and 65 uses a completely different set.
    I am not sure, but if the steering knuckles and spindles are the same on both cars (I do not know) the best thing to do would be to change it all over to the 65.
    The 65 has better geometry than the earlier ones and is one year only.
    This applies to only the v8 cars
  8. plumcolr
    Agreed. But 64 v8 chero and 64 v8 falcon are identical. Likewise 65 chero and falcon v8 use same suspension parts but different from 64.
