65' Front end "clunk" Harsh Ride
Discussion in 'Ranchero Tech Help' started by AimlessMoto, Mar 25, 2020.
  1. AimlessMoto
    AimlessMoto In Fourth Gear
    Townsend, MA
    Got the Ranchero out on the roads and it cruises beautifully.
    However, even the shallowest pot-hole or rift in the pavement can cause a clunk. It's more on the driver's side... Doesn't matter what speed you're traveling.. but it doesn't seem to unsettle the track, so I'm figuring it's not wheel bearings or ball-joint related.
    That, and the ride is unexpectedly harsh! Bumps kinda bash the front end around...
    I've had it up on jack stands on the sub-frame and don't notice anything loose or touching... no witness marks of any kind, and I did give the chassis a full once-over and greased all the fittings I could find (yes I got the inner a-arms inside the spring towers), and put a wrench on everything to make sure it was all tight.
    Kinda at a loss. Any other ideas as to what could clunk around?
  2. 72GTVA
    Strut bushings and associated cross member attachment area?
  3. RancheroRandy
    RancheroRandy In Overdrive
    What condition are the shocks?
  4. beerbelly
    +1
  5. plumcolr
    Check the top shock mount, Also very carefully check the shock tower for cracks. Also possible the upper control arm mount to the shock tower is moving around. Check it's tight to the tower and alignment shims haven't come out.
  6. AimlessMoto
    Townsend, MA
    Spent a good 30 minutes under the ol'girl.
    No cracks anywhere. Power steering piston is a bit leaky. No play in anything. Shims are in place behind the upper a-arms. Tops of the shock towers are good and tight. No bushings on the lower body of the shock where it mounts to the a-arm, upper bushing looks good.
    Shocks are 15 years old, but the car has been sitting on blocks for 10 of them.
    No play in the wheels.
    Stumped.
  7. beerbelly
    Have you checked both ends of the strut rods?
  8. Jimbob
    +1 on shocks, they could have an internal failure. Pull them and compare both fronts with compression test.
  9. The Wrench
    The Wrench In Second Gear
    AmlessMoto You mentioned that you had no lower shock bushings. There should be 4 lower small round rubber bushings on each shock. If you have none on each front shock bottom that is your rattle and it doesn't take much of a bump to make it rattle. The Wrench
  10. pmrphil
    Ball joints, perhaps?
  11. AimlessMoto
    Townsend, MA
    BeerBelly - Yup! Tight and adjusted properly.
    TheWrench - Good to know. The bottom of the shocks have pressed-in studs that go through the little cross bar into the top of the A-ARM... are the bushings supposed to be in the cross-bar or on either side of the stud 'through' the crossbar?
  12. The Wrench
    On the two studs on the bottom of the shock there should be a rubber washer on each stud before putting them in the mounting holes in the cross bar and a rubber washer on each stud and a metal washer on each and then the retaining nuts. The Wrench
  13. AimlessMoto
    Townsend, MA
    The rubber washer on the passenger side is there, but it looks like old electrical tape, all squished and torn. The shocks to the cross mount are metal on metal.
  14. The Wrench
    AimlessMoto, it is probably time to replace those front shocks and rubber bushings. When you replace them let us know if your noise goes away. The Wrench
  15. AimlessMoto
    Townsend, MA
    Can I remove the shocks out of the top of the towers without removing the springs?
  16. The Wrench
    Yes they do come out the top and you DO NOT have to remove the springs. I have found if you place a floor jack under the lower control arm it will be easier to get to the lower shock nuts . The Wrench
  17. burninbush
    Can we verify what year car you are talking about? Getting some bad info here, probably bacause of years getting mixed-up.
    If you have a '71-ish front suspension, there are no lower rubber mount washers, they bolt directly to the front suspension. Refer to pic in post #7, the bottom of the shock bolts directly to the center spring mount. It does have rubber washers at the top bolt.
  18. AimlessMoto
    Townsend, MA
    Title says it... 1965'
  19. beerbelly
    Here's the Monroes I have on mine. They come with rubber washers for both sides of the bottom studs, as well as both sides of the top stud.
    The Wrench likes this.
  20. 65restomod
    Speaking of front ends, what is the tried and true method of pulling the upper control arm as far relieving tension off the coil spring.
    I know there are spring compressors for this but was wondering if anybody has another method.
    I hate to buy a tool that I will use once.
