65 Ranchero emergency flashers
Discussion in 'General Ranchero Help' started by MarkB, Oct 9, 2025.
  1. MarkB
    MarkB In Second Gear
    Nipomo, Ca
    I just installed a factory emergency flasher harness from a Mustang. Surprisingly simple to do (unless you're an old guy like me that doesn't bend as easily as I used to.....). Everything is working fine, however, the the turn signal bulb in the instrument cluster doesn't flash when it's turned on. Is this normal? Do I need to put in a seperate bulb to show when it's flashing? Any help is appreciated.
  2. 1979 RANCHERO GT
    is there a wire from the harness that connects to the signal bulb wire. just splicing it on may make both outside lights flash when the signal is on. 1966 Mustangs all had a dash light for each direction where 1965 used one light, like a Falcon for either direction. A 66 harness could be the problem. 1965 Mustang with generator uses a different turn signal switch than the later alternator model 65/66, that could be the problem. I know about working under dashes it was a lot easier forty years ago. Mustang wiring should work, wiring wise they are just Falcons. Did the harness package say what year it would work on.
    MarkB likes this.
  3. MarkB
    Nipomo, Ca
    It was a used, original harness. No instructions included, but I found instructions online. There's no wire that goes to the instrument cluster for the indicator light.
