66 Ranchero tire size
Discussion in 'General Ranchero Help' started by Jeffrey, Feb 4, 2019.
  1. Jeffrey
    Jeffrey In First Gear
    St. Louis, MO
    There are currently two sizes on the truck. G70 14 and F78 14. What is the original size? Would the equivalent be 225/70 R14? Thanks.
  2. 1979 RANCHERO GT
    1979 RANCHERO GT In Overdrive
    My 79 original size was G78-14 and now it runs Cooper Cobra 225/70R14 . They seem to fit right without going to a 15" wheel. I would suspect your original size was 7.35-14 which would gone to F78-14 then to 205. I'd go with the 225, I think 205 and 215 would look a little small.
  3. PonyExpressRider
    PonyExpressRider In Overdrive
    According to Ford Ranchero, Muscle portfolio, 1957-1979... the 1966 Wheels and Tires:
    Wheel size: 14x5J
    Optional Size: none
    Bolt no./circle dia: 5/4.5
    Tire make, Brand: Goodyear Power Cushion
    Recommends inflation: 24/30
    capacity rating. total lb: 4080
    Carl Steinbarger likes this.
  4. Jeffrey
    St. Louis, MO
    Thanks. I called CarX since they are down the road. They said to use a 235/60. Is that better than the 225/70? Why or why not?
    225/70 means the tread width is 225mm, and the sidewall height is 157.5mm; 235/60 is a 235mm wide tread and a 141mm sidewall height.
    As far as which is better/worse, that's quite subjective, but I'd start with the tire price.
  7. 1979 RANCHERO GT
    Go too big and you might have clearance issues rubbing the frame or fenders at the front wheels when steering.
  8. Carl Steinbarger
    Carl Steinbarger In Second Gear
    Dayton, Ohio
    I personally like taller sidewalls on older cars.. 75 or 80 series tires on stock width rims... But then again I'm old....
  9. colnago
    colnago In Third Gear
    Ridgecrest, CA
    Do you have manual or power steering? The PO of my '64 with manual steering had 225s in front, and found it too difficult to steer. He ended up putting 195s up front, and kept the 225s in the back.
    Just my two cents.
  10. Carl Steinbarger
    Dayton, Ohio
    I actually haven't driven mine yet because of all the snow and cold weather.. I have manual steering.. I'm using 185/75R14 on 4 1/2" wide front and 215/75R14 on 5" rims on back.. As soon as I get the steelies painted I'll post some pics... I'm partial to the older "look", steel wheels, dog dish and taller sidewall tires...
  11. Hillbilly
    Carl, while rubber band tires do give better handling, their ride comfort is pretty low. Like you, I have no plans to get rid of my tall sidewall tires because for my driving style I don't need to be able to feel a blade of grass on the pavement. Nice painted steel rims with maybe a pin stripe and baby moon caps along with a set of quality taller radial tires just looks period correct and the ride quality is excellent. The trick is finding quality radial tires in the sizes you want.
    Kiwirancher and Carl Steinbarger like this.
  12. Carl Steinbarger
    Dayton, Ohio
    "Jeffery", sorry to butt in on your original thread question.. I think "79 Ranchero GT" had the right answer..
  13. Kiwirancher
    Kiwirancher In Second Gear
    Gisborne , New Zealand .
    I am running 195/65 14's front and 215/70 14's rear on my 66. Slight rubber rake , they are on torque thrust 2's. Power steer so easy to drive. I am definitely a sidewall guy too. No rubber bands or as we tend to call them , Liquorice straps , for me !!
    Denis.
  14. Carl Steinbarger
    Dayton, Ohio
    Like I said, I'm old and not in the know.. What are "rubber band" tires and "Liquorice straps"???
  15. TestDummy
    Very little sidewall.
  16. Carl Steinbarger
    Dayton, Ohio
    Thanks man^^^, I feel smarter and younger already...
    Kiwirancher likes this.
  17. Jeffrey
    St. Louis, MO
    I found 4 matching 225's. Hope they work out.
  18. Truckpoor
    Truckpoor In First Gear
    Can anyone tell me the the backspacing of the original wheels? Any problems going with 15's
    Thanks in advance,
    Rich
