67 power steer - pressure hose routing under headers
Discussion in 'General Ranchero Help' started by Kiwi-Guy, Aug 9, 2026.
  1. Kiwi-Guy
    Kiwi-Guy In First Gear
    Auckland, New Zealand.
    Hi I'm running a 351W stroker & C6 auto in a 67 Ranchero with Dougs mid length headers. The power steering pump is a Ford original setup with center rear outlet, just above and fwd of the oil filter.
    Does anyone have a better solution to the original 289 power steering pressure hose/routing, the original pressure hose seems too long to fit neatly under the headers & back to the reaction valve inlet.
    Thanks.
    Alan.
  2. 1978GT
    Figure out the routing you prefer and measure the length of hose required to fit that routing. Then remove your hose, take it to a refrigeration supplier who will transfer your fittings to a new hose. Make sure the clocking of the fittings is maintained.
  3. Kiwi-Guy
    Thanks for the suggestion.
