69 Tach question
Discussion in 'Ranchero Tech Help' started by Cindy, Jul 8, 2019.
  1. Cindy
    Bay Area>>>>Gold Country, CA
    Hey all....my dash project is under way soon, and I’m getting all my new gauges lined up. Got my in-dash tach too, pretty stoked about that. So is it cable-driven, or electric? I’m thinking the latter but not certain. Whadya think?
  2. pmrphil
    Should be electric - I don't think I've ever seen a Ranchero or Torino with a factory cable driven tach.
    Cindy likes this.
  3. Cindy
    Ahh okay, thanks phil
  4. Cindy
    ...do you think there’s a specific wiring harness that I need to use/find? Or can it just be wired in?
    Anything can be 'wired in, but you still need the proper wiring diagram in order to do it.
  6. Hillbilly
    Cindy, Auto Crafters sells a pre made factory wire harness for your tach. You have to drill one hole in the firewall then connect their wires to the power side of the ignition coil. The other end under the dash plugs into the tach. Part number = C90Z-17A299A. Phone # 1-800-228-7346. Lighting for a clock should light up the tach too. Hope this helps !
    pmrphil and Cindy like this.
  7. Cindy
    Thank you, friend. Ordered and on its way here. -Cin
  8. PonyExpressRider
    Cindy,
    My tach has its own wire set, separate from the factory harness, consisting of two wires. They go to the + and - side of the coil!
    Cindy likes this.
  9. Cindy
    Awesome, thanks for the pics, Pony:)
  10. Hillbilly
    Cindy, here is a simplified diagram for how the harness you ordered plugs in. Nothing goes to the points side of your coil. 69 tach wiring.jpg
    Cindy likes this.
  11. Cindy
    Thanks, Hillbilly, I saved that diagram and will print it out.
