70ies Ranchero wheels question
Discussion in 'General Ranchero Help' started by GRUMANIA, Apr 10, 2019.
  1. GRUMANIA
    GRUMANIA In Third Gear
    Germany
    15x6,5.jpeg Hi there,
    I recently bougth these wheels for my 1972 Ranchero.The seller said it came of his Ranchero ( didn`t ask him for the year )
    The wheels are 15 x 6.5" and are stamped with "FORD", the size and some extra numbers, that seem to be part numbers.
    Does anyone know what wheels these are and on what Ranchero or Ford they have been on ? All I could find is an ebay auction, where the seller calles them "Western Turbine Aluminium wheels", with no extra info from which car they come of.
    Thanks in advance,
    Ilja
  2. TestDummy
    Look late-80's Crown Victoria to me.
  3. GRUMANIA
    Germany
    Similar, but the Crown Victoria rim has different ribs. The ribs on mine go down to the hub cap opening
  4. 1979 RANCHERO GT
    1979 RANCHERO GT In Overdrive
    Look like 78-79 Thunderbird diamond jubilee/heritage wheel
  5. GRUMANIA
    Germany
    Yes,
    as they have benn on a 70ies Ranchero, I think they will fit on mine.They really look cool
  6. Dan the ranchero man
    Those were used on the 77-79 t-birds and have seen them on the same year cougars too.
  7. ForistellFord
    Beautiful Foristell Missouri
    Aren't those the ones that like to crack really easily?
  8. TestDummy
    Yes. Not the best design. I guess they are sort of attractive, in a hub cap way.
  9. Dan the ranchero man
    I also suggest some anti-seize around the hub. The aluminum rims were very prone to seizing onto the steel hub and would almost take destroying the rims to get them off.
  10. TestDummy
    Hence the cracking. Good advice. My old F150 rims wouldn't come off at all. I put the lug nuts back on, backed them off a couple threads, then drove around the parking lot, swerving back and forth. That was the suggestion from a Ford engineer. Worked too.
  11. Dan the ranchero man
    we used a 40 ton porta power frame spreader. when the one side came off it left the center still attached to the axle hub. the other side came off with such a bang you thought a gun went off.
  12. 1965 Ranchero 66G
    I liked Sean's solution better, I'd bet that there were some adult refreshments involved in yours.
  13. Dan the ranchero man
  14. 1965 Ranchero 66G
    I would have loved to see that I have done worse I still can't hear very well from my playing with Tannerite last year.
  15. Dan the ranchero man
    it was a buddy's 78 cougar that we were doing this on and when the broken one came off it ended on the front lawn (20 ft) the other one sent us running! (lived at the top of a hill ) it started rolling (with a flying start of course) and took us 10 min (longest 10 min of my life worrying about were this thing may crash) to finally stop it. :eek::eek::eek:
  16. Doc76251
    Doc76251 In Fourth Gear
    Virginia Beach, VA
    That is a classic that should have started with "Hold my beer, watch this......"
  17. Dan the ranchero man
    Yes it should have and a a video to boot. (1989-90 time frame)
  18. 1965 Ranchero 66G
    Memories are better than oldzeimers.
  19. handy_andy_cv64
    I had a set of those, from a Cougar, on my '74 Squire. The way to quickly tell between these and Panther rims (which, incidentally, also fit '72-'79 Intermediates), is that the Panthers have three metal studs, used to hold the center caps to the wheels, along with the different rib style. In addition to the anti-seize compound, wire brushing the mounting surfaces of the wheel and the hubs ensures corrosion won't interfere with removal.
  20. TestDummy
    You are the Cliff Clavin of these wheels, apparently.
    1965 Ranchero 66G likes this.
