71 351C 2 barrel running rich
Discussion in 'Ranchero Tech Help' started by jrnardi, Oct 2, 2023.
  1. jrnardi
    jrnardi In First Gear
    Rebuilt the stock Ford carb and checked timing, plugs and exhaust are very black.
    Should I be looking at the jets? They are "original".
    What else?
    Did you replace the power valve, install a base gasket on it? The 2100/2150 carbs will leak gas if the diaphragm is punctured, or the valve's base gasket is missing/compromised. Also check the venturi assembly gasket, they can rip or squish out on assembly.
  3. jrnardi
    I did all the above, with no help but thanks for the suggestions.
    A new Holley carb ($550) and it runs a lot better.
    BlackBeauty and pmrphil like this.
    Well, you try the low-cost fixes first.
    BlackBeauty likes this.
