71 Digital dash conversion
Discussion in 'Ranchero Tech Reference & Articles' started by grebaba, Feb 7, 2019.
  1. 5.0 Chero
    I would use some thing like this over the bottom hole
  2. grebaba
    grebaba In Fourth Gear
    Ok
    What is it and where do I get it?
    If it is thin enough I would consider it.
    Would order some and see what it looks like.
    Greg
  3. 5.0 Chero
  4. grebaba
    Thanks for the link.
    I think they are to thick for the speedo but I can think of other places I can use it.
    I book marked it so thanks again.
    Greg
  5. TestDummy
    I'm too cheap too. And I usually don't notice the pics are blurry until they are posted.
    I thought red because it would match the readouts. Plus, red.
  6. grebaba
    I didn't think about matching the readout's. I wanted blue leds but they don't have them for the Ford.
    The reason the picture was blurry was I was holding the 2 wires for the LED's together with one hand trying to hold the camera steady with the other hand while taking the picture.
    You can see how successful I was.
    Greg
  7. 72GTVA
    The beer sign was pretty well focused - at least you got your priorities straight. Don't let the contrarian nit-pickers get on you.
    HuevosRanchero and TestDummy like this.
  8. grebaba
    No problem, its all in fun.
    Greg
  9. TestDummy
    Damn right it is. Don't let Serious Sally take it away.
    grebaba and ForistellFord like this.
  10. JOHN SCHULTZ
    JOHN SCHULTZ In First Gear
    I did a similar conversion on my 71, can’t get the gas gauge to work to save my life, what wire did you use to get it to work? Or if anyone has any advice it’s appreciated
    The factory test is to turn ignition on (with the coil power disconnected), then ground the gauge sender wire at the gas tank mounting. If the needle goes full deflection, the gauge and sender wire is good, your problem is at the tank. If no deflection or only partial, your gauge or sender wire has a problem. At the tank, some ground the rheostat directly through the tank and mounts, others are two-wire, and the ground wire's attached to the frame.
  12. grebaba
    Another thing is that the unit is programmable so you will have to ohm out your sender and then program the unit for your sender.
    If that isn't it then I would check my sender to make sure it is good.
    Being as old as these are it isn't uncommon for the sender or the sender wire to be bad and like handy-andy said check your ground wire while you are in there. Bad grounds can cause a lot of problem's.
    Greg
