'72 grille
Discussion in 'Ranchero Parts for Sale LINKS' started by beerbelly, Nov 21, 2019.
  1. beerbelly
  2. 5.0 Chero
    Damn and I thought my prices were on the high side for the Grille center
  3. Rods N Restos
    Rods N Restos In Fourth Gear
    South Jersey
    $200 is going rate for 72 Grille,some want that with broken tabs and needs new paint
  4. andrewok1
    dam glad i got them when they where running $65-$85.00
  5. Rods N Restos
    South Jersey
    I have 2 spares ,1 came with 72 GTS we bought as it had a black painted grille in it and he had the factory silver and black grille so I swapped cause it contrasted better on the flat black of car.
    I also have a parts grille for the pieces of plastic to restore other grilles.
    I may sell the grille out of the 72 Ranchero as I want to buy the custom Billet aluminum grille from Vegas HotRods
  6. 5.0 Chero
    [​IMG][/QUOTE]
  7. beerbelly
    Still lovin' the Pyl 5.0! That was a genius makeover.
  8. Rods N Restos
    South Jersey
    Screenshot_20191123-214631_Gallery.jpg This one is cool too, little different then Vegas Rod Parts billet grille
  9. colnago
    How many gallons per mile does that engine get?
  10. Rods N Restos
    South Jersey
    Not sure but it's about 2000 hp
    545 Stroker with 871 Supercharger.
    My friend Chris in Delaware owns it
    Screenshot_20191123-220536_Gallery.jpg Screenshot_20191123-220548_Gallery.jpg Screenshot_20191123-221103_Gallery.jpg Screenshot_20191123-221005_Gallery.jpg
  11. Rods N Restos
    South Jersey
  12. 5.0 Chero
    It was home built before they were any aftermarket ones
  13. russosborne
    russosborne In Fourth Gear
    Glendale Arizona
    [QUOTE="
    I may sell the grille out of the 72 Ranchero as I want to buy the custom Billet aluminum grille from Vegas HotRods[/QUOTE]
    I'm not having any luck googling that place? Anyone have a link to them?
    Thanks,
    Russ
  14. 5.0 Chero
    could not find them either
  15. russosborne
    Glendale Arizona
    Figures, now that I have seen the grille, I really want one.
    Thanks,
    Russ
  16. 5.0 Chero
  17. russosborne
    Glendale Arizona
    Thanks!
    Russ
  18. Rods N Restos
    South Jersey
    The ones on eBay
    Seller is Vegas Rod Parts
    Sorry got the last part of their name wrong but knew they were in Las Vegas,Nevada 20191124_101804.jpg
  19. Rods N Restos
    South Jersey
    No my buddy Chris said it was from company or person that was building and selling them years ago.
    I call home built a person who builds a custom part 1 -2 times but less then a dozen.if you start mass producing even if its based out of a garage or shop behind your home it's a Commercial Operation as your selling them in mass to the public.
    Usually there are jigs and tooling made to aid in making each one exactly the same.
    "Home Built"or "Home Made" to me means somebody at home took some Aluminum, cut,bent & welded using basic tools you can buy,not special jigs or tooling made specific for mass producing a product over and over again.
    I have made some Home made parts for these cars and even though I had a basic design the second one came out slightly different then the first as I made improvements that made the second easier to build and also easier to attach
  20. Rods N Restos
    South Jersey
    The 1st A/C Evaporator Delete duct
    Screenshot_20191124-112057_Gallery.jpg Screenshot_20191124-113038_Gallery.jpg
    1st had welded nuts for Lower blower case bolts.
    The 1 nut was inside of the duct cover the other nut was on outer flange.The duct cover was shaped on angle on bottom
    Second A/C Evaporator Delete Duct
    Second case I modified original design.Bottom of duct cover was more straight across and L shaped thus exposing both holes for the lower blower box bolts.
    I also just drilled holes and not welded bolts to make it easier to install and owner just use new bolts and nuts to attach
    Close up of holes on flange for blower case bolts going through firewall
    Flange was designed slightly different then the 1st I made
    I made them from store bought tools,nothing I used was fabricated specifically to aid in production of this duct thus it's Home Built,one of.......
