72 GT vs 500 doors and panels.
Discussion in 'Ranchero Tech Help' started by russosborne, Sep 10, 2019.
  1. russosborne
    russosborne In Fourth Gear
    Glendale Arizona
    Is there any difference on the doors themselves, or can I just swap GT panels on to non GT doors?
    Thanks,
    Russ
  2. andrewok1
    the doors are the same you will need 2 small brackets that support armrests,to use gt pannels
  3. russosborne
    Glendale Arizona
    Thanks. I would be taking the panels off so getting the brackets will be easy.
    Russ
    andrewok1 likes this.
  4. 5.0 Chero
    do not forget door handles as well they are different
  5. andrewok1
    :oops: I forgot about the handle thanks 5.0
  6. colnago
    colnago In Overdrive
    Ridgecrest, CA
    Yes, I'm hijacking this thread, because the original question has been answered. I had the door panels off with my '64 a few months ago, and there are brackets that can be used for mounting the arm rests in a second location. Were the arm rests actually at a different location for other Falcon variants?
  7. beerbelly
    I tried to put '64 standard arm rests on my '65, but the screw spacing was too narrow; had to get the '65 versions.
  8. colnago
    Ridgecrest, CA
    That's interesting. I didn't know there were differences in the actual arm rests from '64 to '65. Engine size, generator to alternator, dash trim, probably lots more. But the arm rests are news to me.
