72 or equivalent power steering gear box.
Discussion in 'Ranchero Parts Wanted' started by Tygr1, Nov 15, 2016.
  1. Tygr1
    Tygr1 In Fourth Gear SILVER MEMBER
    San Antonio
    Looking for a good used or rebuilt power steering box to replace the one on my 72 GT.
  2. andrewok1
    https://www.redheadsteeringgears. this place rebuilds your box ,check them out ,or just go to a NAPA ,
  3. Tygr1
    San Antonio
    Thank you again, Andrew. Napa is definitely cheaper than Epay.
  4. andrewok1
    YES ,I agree on that I paid 185.00 with core ,and have no leaks and that is why I changed mine in the first place ,
    I also ,replaced pump ,hoses so as to have no problems in future. I like to go to out state shows once or twice a year
  5. LSChero
    I got a Ford rebuilt box from summit for cheap.You may have sagginaw box(4 top bolts)Which are mo money but quicker steering.Also be aware of
    there was a production change on parts in early 72. When ordering front bushings/bearings.
    andrewok1 likes this.
  6. Jeff B
    Or if you like adventure, you can put a seal/rebuild kit in the box you have. I did it on my old Ranger and it worked fine and was not too hard to do.
  7. Tygr1
    San Antonio
    Mine is not leaking, it's just worn out.
  8. andrewok1
    What LS is talking about is very importanant with the 72 ranchero,!!!!! In MARCH of 72 changes where made to bearings ,bushings and other small parts ,
    to make sure parts are ordered right allways check production dates sometimes it means speaking o someone.!! Mine is a 10/71 so till march 72 I am okay but after makes a difference ,
  9. Tygr1
    San Antonio
    Oh great. Mine was built in March of 72. Wonder which side of the cut off it falls on?
  10. andrewok1
    good QUESTION ,I bet 50 CHERO /or 72GTVA ,those guys are smart on that stuff
  11. Tygr1
    San Antonio
    Just found out it was rolled off the assembly line on March 25th.
    Cindy likes this.
  12. LSChero
    Just check part#on bearings and measure ID/OD on bushings before ordering to save return grief.
    There is date stamp on frame by front sway.Not sure if suspension was assembled prior to completed body rolling off line.
    My frame date is two months prior to completed final assembly.
  13. Alcoed
    Alcoed In First Gear
    Was a tech and later a mgr at Ford & LM dealerships most of my life. If you really want to improve the steering/handling in your '72...throw away your 72 box and find and purchase a '75 up steering gear. They were greatly improved with an new design GM style internal valve. Pre 74 gears had a spool valve that cause a lot of gear play giving the car excessive wander. Both style p/s gears are identical on the outside. We upgraded many ford products both mid and full size with the later internal control valve.
  14. Tygr1
    San Antonio
    NOW you tell me.
  15. Alcoed
    Sorry, just saw your post.
