72 ranchero gt fuel tank
Discussion in 'General Ranchero Help' started by Andyjman83, Jan 11, 2017.
  1. Rods N Restos
    Rods N Restos In Fourth Gear
    South Jersey
    Supposedly the fuel sending unit on 72-73 Ranchero is same as the 72-73 Gran Torino.
    I bought one from Auto Krafters which is correct for our 72 Gran Torino Sport and bought replacement Spectra F8 tank,
    Trying to find out if Spectra makes the 72-73 Ranchero tank with the side fill hole as Tank is basically same except for fuel fill location.
    Here is link for 72-73 fuel sending unit
    https://www.autokrafters.com/p-1032...ank-sender-gasket-sock-filter-d2oz-9275a.aspx
  2. john777
    john777 In Overdrive
    That is a correct statement. My old vent did not fit the tank I purchased. The other point here is that the valve goes to a hose which goes to a hard line, which I removed when installing the new motor years ago.
  3. john777
    The roll of tubing i bought on amazon worked wel land was cheap. We just bent it and used the old clips attached to the frame to run the tubing.
