74 instrument cluster???
Discussion in 'Ranchero Tech Help' started by Purple74, Apr 8, 2019.
  1. Purple74
    Purple74 In First Gear
    Hey guys! I just got a 74 project I’m very confused about all the different instrument clusters ! My project came with three different clusters and 2 different 14 pin connectors Oh and my connector was cut off !!! Car is a 500 NON Gt. My best cluster seems to be 3 big gauges & big clock , and a 12 pin RECEIVER !?!? AND I DON’T HAVE A 12pin connector HELP !! Thanks in advance!
    andrewok1 likes this.
  2. 72GTVA
    rancheromac and ForistellFord like this.
  3. Purple74
    Thanks 72GTVA. Very helpful. i guess i have a 74 standard cluster my question (to whom it may concern lol) what is the difference in the 12 pin connector from 72/73 and 12 pin connector 74/76 article says i cant plug and play ??? Thanks again in advance ps I don’t have a 12pin connector and where can i find one for a 74
  4. Dan the ranchero man
    the size of the plug.
  5. andrewok1
    1972 -73 only 12 wires on plug -1974-76 14 WIRES ON PLUG
  6. andrewok1
    I may have a connector plug & YES I DO 14 PIN
  7. Purple74
    Thanks Andrewok1 but i have 2 different 14pin connectors ( different wire color pin locations) I guess I’m Putting a 72/73 cluster in my 74 if I ca find a 12 pin connector. that site from GTVA said 74 had a 12 pin connector but different from 72/73
  8. 72GTVA
    Match up the cluster you are going to use by the printed circuit number impressed upon on it, and then use that connector and wiring pin out. It is likely you have a 74 which will require the 14 pin connector.
  9. Purple74
    Will do !!! 14pin won’t fit my pcb to big
  10. Purple74
    D2GF 10C956. 51072 1513. These are the numbers on my PCB (12pin) Now what do i do??
  11. 72GTVA
    Wiring diagrams are in the Tech Reference and Articles sections. Do you have the 12 pin connector?
    The wire colors are very constant from year to year - meaning you should be able to make the 12 pin instrument cluster work with a 12 pin connector. What you might lose would be something probably not vital such as a seat belt warning light. Assuming the interlock was bypassed it would likely not even be missed.
  12. Purple74
  13. Purple74
    No I don’t have a 12pin connector! But i can post a pic lol. if i can find a 12 pin connector I think could make it work Thanks GTVA
  14. Purple74
    Any ideas on where to find a 12 pin connector???
  15. andrewok1
  16. Purple74
    Wow! Thanks Andy
    TO BE CONTINUED.
  17. Purple74
    Well got the plug ! Thanks again Andy Matched colors best i could. Only got left signal light I guess i was hoping for the ign lite or oil lite ?? Need some further checking
  18. 72GTVA
  19. andrewok1
    your welcome thanks for the shipping dollars.
    as Dan said you may need to go pin for pin matching up circuits
  20. handy_andy_cv64
    When I was contemplating a swap to a GT cluster in my '74 Squire, I drew up a page showing all the wire colors and identifying what I'd need to get the gauges, clock and tach functional, using diagrams I copied at the local library. That made sure I had correct colors and tracers.
