76' Ranchero Fixer-Upper
Discussion in 'The Stable' started by AimlessMoto, Jan 5, 2015.
  1. AimlessMoto
    AimlessMoto In Overdrive
    Townsend, MA
    As many of you know, I just purchased a 1976 Ranchero 500. 351M/400, FMX 3 speed, stock 14" wheels, all the 100% complete, 0 body rust, 0 frame rust, factory AC. Southern car, lived most of it's life in TX then VA, 1 owner. Last oil change 1995, parked 1999. 70153 original miles, verified by VIN and Title.
    WHEN PURCHASED:
    CURRENTLY:
    WHEN PURCHASED:
    CURRENTLY:
    WHEN PURCHASED:
    CURRENTLY:
    Left To do:
    - Pitman arm seal on steering box.
    - Remove dashboard to replace instrument lights.
    - Remove and troubleshoot radio.
    - Tighten ALL dashboard bolts on the underside to get rid of squeaking.
    - Re-fit window weather stripping to make contact with windows.
    - Get new door speakers.
    THE PLAN:
    I want to make this truck 100% reliable and 100% original before I go making any HUGE changes. I want to be able to drive it around as it was 39 years ago!
    THEN:
    - Re-furbish interior (new carpets, seat cover, and steering wheel)
    - Paint the frame or under-coat.
    - Touch-up the body work, possibly re-spray original color.
    jcgolferVA likes this.
  2. AimlessMoto
    Townsend, MA
    Gas tank replacement sucked for a 1 guy... the worst part, getting the fuel filler OUT of the tank while under the car. I cleaned up the end of the filler (as it had corroded and varnished along with the tank), greased it, greased up the new fuel filler gasket and it took about 20 minutes of brute force on my back to get it to seat properly. No fun. End result is great!
  3. AimlessMoto
    Townsend, MA
    The timing chain was a paint to remove... glad I had a harmonic balancer puller and a pulley puller... The cam gear was the hardest to remove. Tip: undo the cam bolt and remove the fuel pump cam, re-install the bolt about 1/2 inch from touching the gear... then use a pulley puller against the bolt. Popped right off! Also... be careful not to drop the cam locator pin into the oil pan... did that... wasn't fun.
    There was about 1.5 inches of slack in the old chain, and about 11-13 degrees of slack between rotor movement on TDC forward and back. New timing set was under $40... so cheap insurance, and might wake up a few of the lost ponies due to timing slack.
    Also installed the new fuel pump. Very easy to do with the timing cover off.
    Just waiting for my timing cover gasket set so I can bolt everything back up... and also replace the crank seal in the cover.
  4. AimlessMoto
    Townsend, MA
    I took the back glass out and started cleaning up the mess. The PO had used additional window caulking (the black stuff) and clear silicone sealant... OVER the aluminum trim, so I all-but nearly destroyed the two bottom trim pieces trying to remove them. (yes I was using a molding removal tool) I don't know if It'll be worth it to re-install them.
    I did buy new trim clips, and I'm glad, because nearly all of the bottom clips broke during the clean-up process. I will probably install the two upper pieces over the window and wait on an e-bay listing of the two lower pieces.
    I still have to get medieval with a putty knife and my wire brush attachment... but I've so-far cleaned around the 3 holes I found and it seems as though there is no cancer around them... only solid metal. Woo hoo!
    In this pic, you can see the silicone, some body filler on the seam (pinkish/off white color)... and the holes. I did clean the corner out further and there is in-fact no through rust.. only a bit on the surface.
    Here's the smallest hole almost directly in the middle of the window.
  5. AimlessMoto
    Townsend, MA
    Here's the removed radiator... the upper hose mount is holding on by a thread, the metal has become extremely thin and there's not much left to the solder joint.
    The new radiator and water pump awaiting fitment.
  6. AimlessMoto
    Townsend, MA
    Finally got some of the odd-ball stuff out of the way.
    Got the new CORRECT thermostat (only took 4 tries), and cleaned up the thermo housing, new gasket and sealer. Got the correct upper hose for the modified, turns out I had ordered a Winsor hose on accident.
    After that, I have all new belts, oil, filter, and coolant ready to go in as soon as I can get my timing cover back on. Thanks to some of the guys on here, I'm going to slightly modify it to put it back into place... it's been 20 degrees out here, so hard to do at the moment.
    I also have the new rear window seal and 2 used, but good, lower window trim pieces for the rear on the way, so I can finally get to work on the rear window.
    Lastly, the upper door weather stripping wouldn't seal on the back side of the windows on either side. So I called the supplier and they suggested wedging some fender welting behind the weather stripping to help push it out, so that is on the way, and I'll have a chance to fiddle with that.
    Slowly but surely.
  7. AimlessMoto
    Townsend, MA
    This weekend was a good weekend...
    I TOOK IT FOR A DRIVE!!!! Not far, just around the block... but still... IT LIVES!!!
    I added about 5 gallons of gas, dribbled a little down the carb, and cranked for about 30 seconds... then VROOM. Running under it's own power!
    One cylinder was missing at first startup, almost sounded like an exhaust leak, and it was puffing white smoke. I let it warm up for a little bit, rev'd it, and it went away. Purring like a kitten.
    Idle is perfect, rev's up smooth (and strong!).
    I hopped in, put it in gear (no clunks, no jerks) and took it around the block at about 15-20mph (I have mis-matched tires on the back... so I don't want to mess up the rear end).
    Oil pressure was good, temperature was good.
    The only negative was the there was ZERO power steering. The pump was dry (checked after I parked it) but there was no screaming, or whining to alert me of an issue... So hopefully, just adding a little fluid to it will help... but I did notice the power steering box was wet, so there's an obvious leak somewhere in the system... just have to track it down.
    Nothing really to take pictures of yet, and we're expecting 2 feet of snow in the next 36 hours... so this might be the last time for a month I get to play with the 'Chero... but at least I know she fires right up!!!
    WOOHOO!!!
  8. FrenchFan
    Rennes / FRANCE
    Where did you find your knew knobs on windows crank ?
  9. AimlessMoto
    Townsend, MA
    http://www.dearbornclassics.com/win...irlane-galaxie-ranchero-torino-1960-1961.html
    I got mine in clear.
    You have to drill out the flare on the back of your stock ones, and then press in the new ones. I used a rubber mallet. Make sure you use the spring washers that they come with, otherwise it'll rattle.
    It's OK if they're too tight, they will loosen up over time.
  10. ribald1
    Good progress!
    Sounds like it did great for a first run!
  11. FrenchFan
    Rennes / FRANCE
    Alright, thank you.
  12. AimlessMoto
    Townsend, MA
    Just ordered a little touch-up paint and the arm-rests for the interior.
    Getting things lined up for when this snow finally melts.... all 36" of it. :(
  13. azcolin
    azcolin In Maximum Overdrive
    sorry to hear about the white shite bud, where in the country are you ??? upper east coast ???
  14. AimlessMoto
    Townsend, MA
    US, Massachusetts... just got pounded with a 4' storm. Another 5 inches expected Friday, and another 18 inches expected Sunday. Not thrilled to say the least.
  15. 72GTVA
    Global Warming. It is California's fault.
  16. ribald1
    Hey! Not everything is CA's fault!
    Anyway, Al Gore (inventor of the internet and global warming) came from Washington DC.
  17. 72GTVA
    Is too! Read it on one of the 976 signs posted at the hotel pool - "...known to the State of California..." (Even when known elsewhere to be false).
    mo.herbfarm likes this.
  18. ribald1
    OK, most of what the liberals know here (and elsewhere) is false, and we have a slew of very ignorant people that hold themselves in very high esteem, but that goes against the argument for fault. While they are very adept at creating pointless signs, labels, and slogans, they are completely inept at almost every other endeavor.
    The level of incompetence here is so high that were we to have set out to create global warming it would have been a failure saving all of you the misery.
  19. AimlessMoto
    Townsend, MA
    Unfortunately I've had MANY deals fall through, thanks to the glory of Craigslist on both Mustang wheels, and on classic wheels...
    Tonight, I located a set of 14x7's Cragar S/S rims, with good rubber for only $150... if they're still there by Saturday, I own them.
    225/70-14 on rear, 215/60-14 up front. I can always play with tire sizes later down the road...
    The wheels are in decent shape, definitely need a good buffing... if they're corroded at all, I'm thinking of color-matching the spokes to the body color, leaving the chrome lip and center cap.
    We'll see.
    By the way, she started right up in 20 degree weather this weekend. ;)
  20. AimlessMoto
    Townsend, MA
    BAM... $150 = 4 Cragar S/S rims and 4 tires.
    Fronts: 215/70-14 on 14x7 0 offset Goodyear Eagle T/A Radials, about 90% tread depth.
    Rears: 235/70-14 on 14x8 +20 offset can't remember the brand, but they're about 50% tread depth.
    Can't complain.
    I'm psyched I got these.... I was hemming and hawing over going with the Mustang wheels... but I came to the conclusion that 1. I don't want to run spacers if I don't have to... and 2. I want this truck to look like it was a survivor... so going with a vintage set of rims and tires is the way to go for me.
