'78 Cali Car w/460 CID Long Term Project
Discussion in 'The Stable' started by Krazzyk, Oct 8, 2016.
  1. handy_andy_cv64
    The "C4" has nothing to do with the trans type, it is a C6. HOWEVER:
    PJA-C3, 4 C6 400 8 1973 Ford (A) (exc. P/C and fleet) This is the line for this particular trans on Fordification.com's trans application page for 1973-79 cars and Broncos, listing that it would've backed a 400.
    http://www.fordification.net/tech/transapps_73-79cars.htm
  2. Krazzyk
    Krazzyk In Second Gear
    Cedar Park, Texas
    That doesn't sound good if I have any intentions of building this engine up a bit.
  3. ribald1
    It is easy to get a c-6 to handle 700HP
  4. Krazzyk
    Cedar Park, Texas
    So what's it take to doo that?
  5. ribald1
    Are you going to go to 700HP?
    If only going to 500, quality clutches and an improved servo are all that is needed. A shift kit is optional.
    Higher and you are getting into Kevlar friction products and a billet servo along with stronger input and output shafts. Maybe even a wide ratio gear set and bearing upgrade.
    And, don't forget, fluid cooling capacity. I would recommend the highest capacity auxiliary cooler, no matter what power the engine makes.
  7. ribald1
    The 'highest capacity' cooler would cost more than a new transmission.
    I run a fan forced unit over the rear axle that then routes through the radiator to keep the fluid from getting too cold at idle and cruise. That one was over $500 and no where near the most powerful one.
    It is adequate for the around 700HP I run with a 2500RPM convertor. It could probably handle a bit higher stall, but not a 3500 if used for extended periods on the street.
    For a 500HP application and 2500 or under convertor a large front mounted cooler without a fan will work well.
    Mike1969 likes this.
  8. Krazzyk
    Cedar Park, Texas
    As far as trans cooling goes the car had a new ~ 12" x 10" stand alone cooler and when we do the A/C that evaporator has another cooler in it as well. Figured I link them together and that should be good. I remember being advised not to use that one but I'm thinking it will be fine for what we're doing. It's not like I'm going to track this car or be making 1000 HP.
    I was just checking out Holly's new Sniper EFI last night. That thing is awesome! It does a lot for the money. Check it out.
    We got our two new 12" electric fans and some other parts in yesterday. It was a little like Christmas. LOL
    I'm drawing up an aluminum shroud in AutoCAD Fusion 360 and then I'll make it at the Tech Shop. Should be cool.
    More stuff showing up all the way into next week.
    Tore off the Oil pan last night to find the engine has Speed Pro pistons in it. So far so good on that end.
    On the heads we have. If I want to put roller rockers on there and leave the cam a solid lifter, what's the highest lift I can use without having to do major head work to make it work? I'm looking for that real loapy sounding cam.
    I'm really looking at that sniper system from Holly. I've got to look at the math and see what I can get out of selling the new/old stuff I've been taking off of this thing to pay for the newer, better, faster go fast stuff. lol
  9. Krazzyk
    Cedar Park, Texas
    [​IMG] Okay, sorry it's been a little while since I posted anything on here.
    Since the last post the frame is out and we power washed it and the rear axle housing. I've got to head out to work in a min so I'll post the pictures and video and come back later to fill in some gaps.
    I'm not thrilled with the way I have the body supported up in the air right now. There are two rubber blocks at each end, the fronts on the outer part of the floor board and the back end has a board across the gas tank supports that are part of the underside of the bed. I'll change this around tonight once I get home from work. I'm going to run boards down the channel where the frame normally goes on each side and also under the ass end.
    [​IMG] [​IMG] [​IMG] [​IMG]
    Spent the day power washing the frame yesterday with Decklin.
    Found some of the body mount bushings are actually in VERY good shape. Anybody need a part number? LOL
    [​IMG] [​IMG]
    Started to do my own powder coating on the small stuff. The powder gun at the Tech Shop was jacked up so I've got to redo some of it. Should've stopped as soon as I knew it wasn't right. Oh well, lesson learned. I ordered my own gun so once it's here I'll start back up.
    The purpleish color is suppossed to be a redish purple so I want to try that again with my new gun before I ditch that color. I really like the US Penny Vein for the frame.
    I'm going to need to sand out all that powder before I push new bushings in, I know. Had to coat something! I was dying waiting to see what it looked like. lol
    Went ahead and bought the new Holley Sniper EFI complete kit for $1,295. I think it's a steal for all the stuff it does. If you don't know anything about it you really need to look it up. Amazing how far we've come.
    Welded in cross braces and then boxed in the control arms. Don't think I'm going to roll with these. They're heavy enough to install on a Sherman tank now! lol
    If anyone can help. I need the side marker light that goes on the driver's side rear quarter panel. The lens on mine is broke.
    Gotta run for now.
    Later
    Wow. This rig's gonna be a shiny penny when you're through. What was the cost on the EFI kit?
  11. Krazzyk
    Cedar Park, Texas
    $1,295 at Jegs.com
  12. LSChero
    That the cleanest body/frame i have seen!PO took good care of her.Great job you and your boy are doing!
    I have needed marker light,but will be a few weeks till i get my part collection out of hock.
  13. Krazzyk
    Cedar Park, Texas
    Cool! Pm me with what you're looking for on those.
  14. Krazzyk
    Cedar Park, Texas
    [​IMG] [​IMG]
    Question. Does anyone know if I can powder coat the diff face without taking the diff completely apart?
    I'd have to bake the entire thing for a total of about 20 minutes at 400 F.
    Other than the front pinion seal I don't see any parts with rubber on them.
    Thanks.
  15. aquartlow
    aquartlow In Overdrive
    There is an O-ring on the pinion housing, resides within the case when assembled. You can remove the housing by unbolting, remove the O-ring, do your coating then re-install after heating. Will not change gear's wear pattern, removing and then re-installing the pinion seal could change the wear pattern if not careful. If you mark the pinion and pinion nut before removal and "just" go past where these two marks lined up you should be fine. Mark the pinion/ring gear so you can make sure they are "timed" as before you removed the front pinion assembly. As to not open a "can of worms", I believe I would clean it up and spray with whatever good quality epoxy paint I could find. Your ride though, you have to make that decision.
    EDIT: after relooking over you pics, you will need to or rather should now have to take the differential to a driveline specialist to make sure the backlash and gear pattern is returned to a good contact reading since you have already removed the pinion yoke without marking(I am only assuming here) the pinion shaft and pinion nut(if the crush sleeve is still installed). Unless you have experience in differential gear set up, you can get lucky and assemble it and get 100K mile service or unlucky with a 10 mile service life(possibly less) out of those gears. Just saying. If you do take this diff to a pro, have them install a solid spacer with shims(this gets rid of the one time use crush sleeve) on the pinion shaft to set gear pattern so you could always replace the pinion seal without going through with resetting/checking gear pattern. Good luck
  16. aquartlow
    Krazzyk,
    If you have the necessary tools, another option is removing the pinion assembly and remove the outer pinion bearing, remove the pinion from the pinion housing, measure the crush sleeve's thickness, then order a solid spacer/shim kit off of Ebay and install the solid spacer/shims to perfectly reflect the original crush sleeve measurement(there could also be shims used depending on machining tolerances, so those need to be taken into account for overall measurement if used). Do not mess with the 2 side bearing adjusters. I would still advise a driveline specialist but if you are careful and have the tools this can be done at home. Sorry to give a bit of bad news, better to know now though. Just trying to help.
