A quick question RE: 460 PI engine
Discussion in 'General Automotive Questions' started by handy_andy_cv64, Apr 25, 2017.
  1. aquartlow
    I found the mid-70's 460 engines used the Delco style starter, leave that in the trash and get a PMGR starter for a '92-'96 F250/F350 with 460/E4OD combo. They are a direct bolt in with just a simple wiring change in most cases.
    We're considering that, for both the Barge and Bear. I have one on Babe, and it's soooo much better than the stock starter. You still use the fender solenoid, but now it triggers the starter's solenoid.
    aquartlow likes this.
    So I figured out the deal with the bolts that don't have flanges; they're the VIN 'A' main cap bolts. Apparently, Joe didn't keep them with the main caps, and I have zero idea where the Hell those are....*rolls eyes*
    We're almost ready to slap the first head on, bolts are cleaned, gotta finish cleaning the block.
    *sighs, slumps shoulders* Well, I guess all the bolts I found, that are head bolts, aren't the only head bolts for this block. The outside bolts are longer by a half inch(?) or so. Sonofa...gun.
    And the ones I had found, that didn't have a 'flare' on the heads, those are smaller-diameter.
    Found the shorter head bolts. Here's where I embarass myself...they were there all along. When I separated out the bolts, I knew at that time there were two lengths, and I had two full sets. Shows you how much I'm paying attention.
    So...driver's head is installed, bolts oiled and in, torqued to spec. Passenger head...not yet. We just discovered the lower rear bolt is prevented from going in because of the evap case. Phooey. I do not want to lift that freaking boat anchor of a head to slip it in, as even between Joe and I, it put the hurt on my back, and likely his, too.
    I might see if I can rig the cherry picker to lift it, so I can slip the bolt in and put it back down.
    With Joe, we were able to lift and rotate the head on the lower front bolt and dowel, insert the bolt, and rotate it back onto the block properly, then torqued it down. That lower rear bolt was so tricky,it broke my 3/4" wobbly socket. Now I gotta find a Snap-On guy....
    So Saturday, I got the valve train installed, and yesterday morning, Joe and I installed the intake manifold:
    Starting to look like an engine. I'm dealing with the carb (yes, it's a 4300-D, but it's rebuild it at about $275 or buy a Holley 4160...for about $275), and we have to find all the little parts that go on it. We hope to have it running around the time I get back from Washington State next month.
