Ac vacuum switch
Discussion in 'General Ranchero Help' started by Ran Man, Mar 6, 2024.
  1. Ran Man
    Ran Man In Fourth Gear
    Does anyone know if afaulty switch can cause air not to blow through your ac vents?
    I changed the actuator today with no luck on fixing the issue.
    The air comes through the floor and defrost just fine.
  2. thebruins
    thebruins In Third Gear
    Check out the diagram below. It's for a '79 but I'm assuming it's more or less the same for other years.
    I guess the actuator is not getting any vacuum, so perhaps a broken hose or a faulty switch? (defrost is default when the switch has little or no vacuum)
  3. Ran Man
    Thank you Bruin for the info
  4. 1979 RANCHERO GT
    Did you get both vacuum plugs plugged in, the 3 port upper and the lower 9 port ? The upper one is easy to forget. I forgot the upper one, fortunately only had to get the cluster back off (the worst part to remove). If you find some controllers in wrecking yards they are worth picking up, I drove with a broken one for a year before finding one. Somebody is going to need one.
  5. 1978GT
    NOS units come up on eBay from time to time. About a year ago I snagged both for under $25 total shipped. Good spares to have on hand.
  6. Ran Man
    Very nice
  7. The Wrench
    The Wrench In Second Gear
    Ran Man, you may have already checked this but have you checked the vacuum reserve can under the hood ? it's either mounted to the firewall or on one of the fenders under the hood, that can has a one way valve that makes it hold vacuum for the system. If you haven't checked it you should. The Wrench
  8. Ran Man
    I did check that and it held vacuum. Everything works as it should except for the AC. Defrost, floor, vent all work perfect. I checked to see if any vacuum hoses were cracked but didn't find anything. I also put on a new actuator that controls the door. I am not sure where to go from here.
  9. Ran Man
    I did get both sets plugged in
  10. 1978GT
    Based on that, the fault is at Door 6 (A/C Heat Door). Take a closer look at the diagram and chart at post #2 by thebruins. You should be able to figure out the problem.
  11. Ran Man
    You would think I should but I haven't yet.
  12. 1978GT
    Pull the hose from the actuator and check for vacuum, either full or partial depending on the switch position (see chart). No vacuum = bad switch, vacuum = bad actuator, actuator not connected to door, or door stuck shut.
