Add on overdrive & beefed up Ford transmissions
Discussion in 'Ranchero Parts for Sale LINKS' started by ThirdTimer, Mar 28, 2010.
  1. ThirdTimer
    ThirdTimer In First Gear
    Hey y'all!
    I was researching overdrive transmission options for my '77, and I came across this:
    http://www.transmissioncenter.net/gear_vendors_overdrive.htm
    There's a longish video that discusses various shifter options here:
    http://www.gearvendors.com/videoclips/sema08-V8TV.html
    Essentially this is an overdrive unit that bolts onto the back of the transmission. Drops the ratio by 22% when engaged, and adds some 'split shifting' options for you performance types. It isn't cheap, but definitely is a cool new option to think about!
    And it works with the overdrive trannys as well, giving you even more 'gears' to play with!. I could have used this on my '02 Dodge van when pulling the trailer... my transmission probably would have lasted longer.
    They apparently have C6, AOD, & other trannys for sale too (and an AOD conversion kit for Mustangs - not sure how well that translates to Rancheros). If you want a beefed up transmission, there are several performance levels to choose from:
    Just thought I'd share! :D
  2. Giska1
    Thanks for sharing. Looks like a good option for the C6 for me if i'm going big on cui and HP :cool:
  3. jeff931
    jeff931 In Second Gear
    Langley, BC, Canada
    I looked into this GearVendors overdrive for my C6; it's $3200 for my C6!!! :eek:
    I could buy three AOD's for that price!
  4. 5.0 Chero
    I just sold one a while back...$800
