Another guitar build
Discussion in 'Lounge' started by beerbelly, Jan 25, 2025.
  1. beerbelly
    This is the 3rd version of my copyrighted design, the AstroCaster. This time instead of a flat slab body like the previous two, I'm adding some 3D carving to add some dimension to the shape. I'm also angling the pickups, and matching that angle at the heel on the neck.
    I buy the necks with a 'half paddle' headstock, ready to shape to your own design. I use this design on all my AstroCasters:
    Then I made some routing patterns out of 1/2" MDF to include with my original body pattern:
    Rough cut the body to shape, then starting routing using the patterns:
    Then started shaping the body to create some 3D dimensions:
    The color will be Dupli-Color Paint Shop 'Burnt Orange Metallic':
    FrenchFan, Buds 67, MarkB and 2 others like this.
  2. RancheroRandy
    Very nice! My middle son (of 3 boys) made a guitar from a cigar box back way back when that actually sounded pretty good because of the type of humbucker he used and the tube amp. Shades of his old man using diff mics/amps for his harp blasting...
    beerbelly likes this.
  3. beerbelly
    Vinyl sealer and white lacquer base coat on:
  4. andrewok1
  5. beerbelly
    Yes, a small portable compressor and an LVLP gun. I also have an airbrush if I want to do shading.
  6. beerbelly
    First color coat on:
    Buds 67, FrenchFan and Kiwirancher like this.
  7. pmrphil
    Looks like a copper - orange - gold mix. Is there a name to the color?
  8. beerbelly
    Dupli-Color calls it 'Burnt Orange Metallic'. I like it!
    Buds 67, Saff54 and pmrphil like this.
  9. pmrphil
    Duh!! :oops::rolleyes:
    If I had only looked at the can before I opened my piehole :confused:
    Buds 67 likes this.
  10. beerbelly
  11. beerbelly
    I was holding off starting the clear coats 'cuz the weatherman was predicting snow this week, and I spray outdoors. Ha! Weatherman got it wrong- it's a blue sky, windless day today, so clear coats are getting started. I think the roasted maple neck is looking great with the body color.
    MarkB, Kiwirancher, Buds 67 and 2 others like this.
  12. beerbelly
    Pickguard done:
    Buds 67, MarkB and Jeff B like this.
  13. pmrphil
    What material do you use for that?
  14. beerbelly
    MarkB, TestDummy and pmrphil like this.
  15. uk ranchero
    uk ranchero In Third Gear
    love the color, close to my Ranchero
  16. beerbelly
    Final clear coats on, now the wait for lacquer to cure before wet sanding and polishing. That color is pretty awesome.
    MarkB likes this.
  17. pmrphil
    How many coats of clear, and how much do you burn through after final finishing?
  18. beerbelly
    This one has 9 coats, and I imagine I'll go through half of those wet sanding & polishing.
  19. beerbelly
    Body mocked up:
    Buds 67, Saff54, Jeff B and 4 others like this.
  20. beerbelly
    Spent all day wet sanding and polishing the body; it's beer-thirty now.
    Buds 67, MarkB, pmrphil and 1 other person like this.
