Another new guy
Discussion in 'New Member Welcome Center' started by neil brown, May 11, 2019.
  1. handy_andy_cv64
    As this is an inline engine, I forgot that it feeds oil through the rocker assembly. Man, I'm forgetting too many things. But yeah, as it's not a canted engine, it lubes the arms that way. I wonder if the engine has an oil feed issue through that path, and the line was added as a stopgap.
    neil brown likes this.
  2. 65restomod
    Ok , not quite sure what a "hollow rocker tower stud" is
    If you mean a hollow rocker shaft with oil being fed from below then I get it
    But with the added oil line at the top of the valve cover, how is that lubing all the rockers from the top? Just curious
    That is what he meant, and as I had said, an oiling rail (spray bar) would need to go under the valve cover to be effective
  4. neil brown
    neil brown In Second Gear
    UK
    I think you can see the stud here, it’s hollow, the oil line attaches to it.
    I think possibly your right, maybe a stop gap for a blocked oil passage, whatever it is, I’ve left it, just tidied it up,’ let sleeping dogs lie’ as they say
  5. uk ranchero
    uk ranchero In Second Gear
    triumph [ cars not bikes] used to make a 6 pot that got modded in that way because some said it improved the oiling of the valve gear others said it reduced the oiling of the bottom end
    With the proper viscosity oil, the bottom end is still protected. I have a feeling there were as many arguments about that as the arguments about the best oil for SU carbs.
