Anyone have luck finding a bed replacement?
Discussion in 'General Ranchero Help' started by JonVeeDub, Aug 14, 2018.
  1. JonVeeDub
    JonVeeDub In Second Gear
    NorCal
    I'm starting to think there is a bias against Rancheros. Do you guys just fab out a replacement bed or is there place everyone uses? My 66's bed is rotten and need to replace, no chance to fix it. Thanks guys
  2. ribald1
    The closest thing I have seen is the replacement for the Bronco rear floor.
    Would take a bit of fabbing to use, but without a tape measure I doubt anyone would notice the difference.
  3. JonVeeDub
    NorCal
    That's a phenomenal idea!!!
  4. davis
    davis In Maximum Overdrive
    LB, CA
    there is bias against rancheros. Elkys get all the attention and repo parts first. gotta love the Chebby.
    JonVeeDub likes this.
  5. Huevos
    How much of the bed floor do you need?
  6. JonVeeDub
    NorCal
    the piece that butts up to the cab. I would say that a good ten inches of the bed that touches the cab is gone.
  7. TestDummy
    If that much is gone, I'd bet there is more rust you'll have to deal with elsewhere.
  8. JonVeeDub
    NorCal
    Oh god yeah. The whole floor is smoked, and so is the metal that is at the base of the rear panel under the rear window that matte up with the bed. But..... I've got started replacing the floor boards and I (as figured) finding a bed replacement had become the most difficult part to find
    ForistellFord and TestDummy like this.
  9. Sparkes442
    Sparkes442 In Second Gear SILVER MEMBER
    Martinez, CA
    I've got a 1966 Ranchero -- I found that the rubber bed mat for a Dodge Dakota fits almost perfectly in the bed of my Ranchero. The cut outs for the rear wheel tubs are slightly bigger (longer) than the Ranchero but everything else fits perfectly. So I think the metal bed of a Dodge Dakota might just work. Just a thought !
  10. PonyExpressRider
    PonyExpressRider In Overdrive
    Rear floor of a 66 Fairlane Wagon? Maybe?
  11. JonVeeDub
    NorCal
    What year is that bed mat you are using from?
  12. JonVeeDub
    NorCal
    Just noticed you're out in Martinez, I work at Shell. would love to see a 66 thats not torn down sometime.
  13. kal
    kal In Third Gear
    Charleston WV
    would a bed floor from a another make honda ridgeline chevy el camino subaru brat/baja etc.. work?
  14. 72GTVA
    If you can do relatively "quality" body work/sheet metal forming you can use prefab bed repair panels or a whole replacement bed from a late model truck as suggested above about the Dodge Dakota. I replaced an entire '72 Ranchero bed with an F-150 bed - split it down the middle and then fabricated what was needed to blend it to original appearing contours.
  15. 72GTVA
    This was during the fit up of the aforementioned F-150 bed, bear in mind the '72 - 79 Ranchero are full frame cars and not the unibody such as your car. The F-150 bed was wider and longer and required trimming and narrowing, I elected to take the excess out of the middle to keep from having to form right angle bends at the edges in ~20 gauge steel with no sheet metal brake.
  16. andrewok1
    looks like it come out well ,hard to bend 20 gauge
  17. 72GTVA
    Same place in the project, the underbody...
    Same car, a little earlier in the fitting/fabrication - had to hand make the cross brace and then the bottom of the tailgate well:
  18. handy_andy_cv64
    Wow. Babe doesn't need that much repair to her bed, but I'm sure she's gonna need a body shop for the repairs to the front right corner floor and box.
  19. kal
    kal In Third Gear
    Charleston WV
    Yea on mine box fine & sealed it good just got couple places under the box an a couple small places on passenger floorboard needs fixed come next year. Its a wonder ford just not put a F series 6 foot bed on these vehicles an go with that to cut costs. An why they put the tailgate handle on the inside instead of outside like the F series trucks.
  20. Sparkes442
    Martinez, CA
    Jon: We could meet for a cup of coffee …. what is best for you ?
