ATV in a 1973 Ranchero?
Discussion in 'General Ranchero Help' started by vespaholic, Nov 14, 2019.
  1. vespaholic
    vespaholic In Third Gear
    Wayne, PA
    anyone know if a full sized ATV will fit in the back?
    Thinking about downsizing to a Ranchero but I need to move my ATV in it
    Thanks
    That bed will not allow an ATV to drive up and in, because of the rear body design. The sides of the T/G opening are closer to each other than the bed sidewalls themselves, so an ATV may or may not fit between them, depending on its track width. But a '73 has very good towing ability, so what about a low-slung utility trailer with wind deflector, to move your ATV around?
  3. LSChero
    My Kingquad fit with tail gate down,50" wide.Its tight,trailer is the way to go.Welcome to site!
    One thing to think about-- in pulling the trailer, adding air bags to the rear springs will help with sway control without the ATV in the bed making the rig roll.
  5. vespaholic
    Wayne, PA
    Thanks for the replies.
    Im most likely not going to buy a trailer only to trailer the ATV maybe once a year.
    Plus I have no place to store a trailer.
    LSChero I have a Yamaha Grizzly which is probably the same size as your Kingquad.
    Does anyone happen to know the measurement between the wheel wells on a 1973 Ranchero?
  6. The Wrench
    The Wrench In Second Gear
    48 inches
  7. vespaholic
    Wayne, PA
    48" Between the wheel wells??
    That's great & surprising!
    That's the same as my C20, so width won't be an issue.
    I did not realize Rancheros were so wide in the bed!
    Thanks!
    Yeah, 48" is universal, insofar as construction materials are concerned.
  9. vespaholic
    Wayne, PA
    How about the bed dimensions of a 1970-71?
    Anyone know?
    Thanks
  10. TestDummy
    I don't know exactly, but it will haul more than 90% of the new 'pick up' truck beds.
  11. 72GTVA
    Unless you get one like mine.
  12. TestDummy
    10% are real trucks.
  13. 72GTVA
    Had to go to the stealership and order mine, they didn't have any on the lot and weren't expecting any...
  14. burninbush
    Hi ... don't have the answer, but can tell you it's a few inches less than 48" wide between the wheel wells. As I discovered the first time I tried to haul some sheetrock in my previous '71.
  15. vespaholic
    Wayne, PA
    So the '70-'71's are narrower than the '72-'76's.
    That helps
    Thanks
