We were looking for a replacement battery tray. Wondering why the same part number is used for 2 different parts.. The 22F battery and the 24F battery one tray is 9-1/8 long one is 10-1/2 One doesn’t work with a/c either.. no way of knowing what they are selling unless they state the dimensions, because both trays have the same part number ... the 9-1/8 tray is way to short, holes don’t line up yet everyone states it fits a 1968 Ford Fairlane , or Ranchero
Mine is a modified tray from a 2006 F-150 (I added a bracket on the bottom from the original tray). It's galvanized and has the lower hold down for added aesthetics.
I just replaced the battery tray in "65. It had a original style F type tray with the hold down bracket on the end and the battery that the PO had someone put in did not have the end tab. Found a replacement tray from Summit racing that works with a little lower brace manipulation and top mount hold down https://www.summitracing.com/search...&SortOrder=Ascending&keyword=SDK-C5AZ10718KIT SDK-C5ZZ-10732-D https://www.summitracing.com/search...&SortOrder=Ascending&keyword=SDK-C5ZZ-10732-D
I made my own from Lexan (acrylic) for my '75 GT. Will not rust and I added a drain hose so drippings will not attack the fender well.
Macs / Auto Krafters has the bigger tray. You may have to chop down the clamp to fit the fan/shroud/radiator.
