Bed Drain Cover
Discussion in 'The Stable' started by RancheroRandy, Nov 5, 2018.
  1. RancheroRandy
    RancheroRandy In Fourth Gear
    Got the bed drain cover hinged...first project to make the new heap "mine"....plenty on the list = $$$ Hinged Bed Drain Cover.jpg
  2. ribald1
    Perfect place to stash a shotgun, rifle, and ammunition.
  3. RancheroRandy
    How'd you know? ;)
    I'm old enough to remember the "good old days" when you didn't have to stash them...hang 'em in the pick-up and go to HS with them...
    1965 Ranchero 66G likes this.
  4. RancheroRandy
    So I rerouted the fuel line today. Interesting how some people "overcome" problems, namely the fuel line lying on the exhaust: header wrap, that will do 'er! Sheesh... Fuel line mess.jpg
  5. Jeff B
    Please forgive the question I am asking, don't mean to cause alarm, but does there need to be any ventilation in that space to remove the gases (hydrogen) when the battery charges?
  6. ribald1
    The amount of hydrogen released by a battery is very small unless the battery is being extremely overcharged. You can tell how much hydrogen is being created by noting how fast the liquid in the battery disappears and needs to be replaced.
    Hydrogen is lighter than air and he would have to take serious measures to make the area air tight before it could accumulate there.
    I work in rooms with hundreds of batteries in use, some have over a thousand, and these places don't blow up due to hydrogen build up.
  7. RancheroRandy
    I didn't like the 4 different shades of red that were in the interior so I have been slowly changing things over to black...oh, and a new steering wheel. New Seat.jpg
    Vinyl paint on the door panels worked nicely but the armrests seemed to flake pretty easily even after meticulous prep.
    Did you use paint instead of dye? There should be a vinyl dye that soaks in, so that you don't have flaking.
  9. DJ Clinton
    DJ Clinton In Second Gear
    Mesquite, NV
    I used the same gauge console, but decided to go black and didn't use the polished metal insert, and went with black framed gauges.
    RancheroRandy likes this.
  10. RancheroRandy
    I used paint (Duplicolor) because it supposedly was "flexible"....I guess I'm still naïve in my old age... :oops:
    Ah. Some are, like Imron, but the surface has to allow the paint to grab. But look into whether there is a dye for your color; I remember someone telling me that was how they changed the parts color for for their replacement interior.
