Body mounts
Discussion in 'Ranchero Parts Wanted' started by Paul Vaccarella, Apr 13, 2019.
  1. Paul Vaccarella
    Paul Vaccarella In First Gear
    Sydney Australia
    I’m finding very hard to find after market front body mounts for my 72 Ranchero. Can someone please help me.
  2. andrewok1
    http://www.ranchero.us/forum/index.php?posts/261245/
    check this post link on the stable ,above
    i just bought all the body mounts for the 69-72 chevelle are the same ,as our cars kit with all buhingds and bolts i found on ebay for 135.00 /AND Y
  3. Paul Vaccarella
    Sydney Australia
    One problem I’ve only noticed that one of my body mounts is worn out and that’s the drivers side front in the whee well. I have already all the drive train installed now. Is it still possible to fit body mounts as I may replace the whole lot ???
    andrewok1 likes this.
  4. andrewok1
    yes - its a bit harder ,HuevosRanchero in above link ,Did his while the rest was together
    Paul Vaccarella likes this.
  5. Hillbilly
    Do one side at a time. I learned the hard way on a four door 57 Chevy. It took me nearly a year jockeying back and fourth with shim packs to get that rascal to sit level and have all four doors actually fit in their openings. I had no idea how flexible those cars are when the body is separated from the frame.
  6. Paul Vaccarella
    Sydney Australia
    Question guys what is the rods above front shocks I need to replace bushings ? They can be seen from the engine bay. I’m trying to upload picture and it won’t let me ?
  7. Hillbilly
    Upper "A" arm bushings. They can be replaced at home if you have the right tools. Usually that requires having a large press you can use.
  8. Paul Vaccarella
    Sydney Australia
    Thanks
