brake boosters
Discussion in 'General Ranchero Help' started by RickMc, Oct 6, 2021.
  1. RickMc
    RickMc In Third Gear
    Carid.com has a stock of boosters for the 77-79's. Passing this along as I know they have been hard to find. 500 in stock(centic rebuilds) so some other vendors may have as well.
  2. thebruins
    thebruins In Third Gear
    Just a heads up for anyone considering that Centric booster. I had bad luck with it as it simply didn't fit. It appeared to be an '80s Thunderbird booster and the studs on it simply didn't line up with the holes in the firewall. Other people on the internet have complained about that as well although some people actually did get the right booster. Roll the dice...
    Could the firewall holes be hogged out to make it fit? Or would you have to drill new holes?
  4. thebruins
    You would have to drill new holes. Also, the Centric booster has a slightly angled mounting surface which would tilt the Ranchero's master cylinder up, and the pedal push rod is way shorter so the Ranchero's brake pedal would be closer to the floor. I'm sure someone could get it to work, but I simply cut my losses and had another Ranchero booster rebuilt.
    I'll let the pictures do the talking, the centric booster and the booster that came out of my '79 Ranchero side by side.
  5. pmrphil
    Crap, that's not even in the same ballpark :(
    The Centric one looks like an Explorer booster.
  7. uk ranchero
    uk ranchero In Second Gear
    when i removed the failed booster from mine i discovered some clown had cut off one of the studs to make it "fit"
  8. RickMc
    And of course,recieved a email now on backorder! Frustrating.
