Broken shifter in my '64
Discussion in 'General Ranchero Help' started by Blanco, Aug 5, 2012.
  1. As Is '66
    Southwest Georgia
    The plastic "tabs" broke and my "horn ring" fell off in my hand, they break fairly easy...
    BE CAREFUL/Gentle with it...
    Rain cooled things off here today,
    66
  2. Blanco
    Blanco In Overdrive
    Los Angeles
    OK so how do I get these wire off this to pass them through?
    So I can replace the collar?
  3. Blanco
    Blanco In Overdrive
    Los Angeles
    & does this look ok?
    I've never seen one before so I'm not sure?
    In order to get the wires out you need to take them out of the connector on the other end. There is a special tool to accomplish that.
    Also, write down the location of every wire so they go back in the connector properly. They just snap in when reassembling.
    That shift lever is quite worn. It may work, but should be welded up or replaced.
  5. Blanco
    Blanco In Overdrive
    Los Angeles
    Figures! :rolleyes:
    Ok maybe I'll order another one along with the collar.
    Thanks.
  6. ribald1
    You can make the tool from a piece of thin metal (I would use a beer can).
    Cut a strip just over 1/8 inch wide and bend and bend it around a 16 penny nail lenghtwise. Hold it with needle nose pliers and push it in on the plug side of the connector, centering it on the gap in the terminal.
    Push it in, then give the wire a tug. It will come out.
    As I said before, going back is easy, they just snap in.
    I sugested the beer can so the pain will be dulled if you cut yourself doing it this way;)
  7. As Is '66
    Southwest Georgia
    UNQuote.........
    The thin metal piece from a windshield wiper blade assembly is good for making this tool also...
    I make & keep those "special tools" as/when needed...
    You can doit,
    66
  8. Blanco
    Blanco In Overdrive
    Los Angeles
    I'll wait till I get the part to try this, Yet it seems as if it would be easier to simply cut the wires & then re-attach them?
  9. ribald1
    Not really, cutting and splicing properly will take a lot longer to do and you risk connection problems down the road.
    Once you do the first wire, you will have it figured out, and the rest will pop right out.
    Not only that, but that type of connector is in several places, so the skill will come in handy in the future.
  10. Blanco
    Blanco In Overdrive
    Los Angeles
    Ok, I'll try... :eek:
  11. As Is '66
    Southwest Georgia
    On the side of the connector there is a Barb that holds it in place, slip the tool over that barb and it`ll slide outta there...( easily - after you figure out the first one)
    Tip # 1) even with good eyes, reading glasses are helpful...
    Good Luck,
    66
  12. Blanco
    Blanco In Overdrive
    Los Angeles
    Figures C&G say they only have the $75.00 dollar part & are out of stock on the $30.00 part & dont know when their getting the cheaper one again.
    They say the parts are the same its just the company that makes them charges more.
    Does anyone know where, I can find the cheaper one.
    Money is very tight right now & I dont wanna start bouncing checks over this.
    Seems like a bait & switch deal to me. :mad:
  13. kirksss32
    kirksss32 In Overdrive
    michigan
    why not just go to a pick en pull an get the whole coloum out of a van,, any short shaft will do then you got a new coloum with tilt.....
  14. 5.0 Chero
    Man I gots to do all your research!!!!!!!!!!
    http://www.autopartswarehouse.com/sku/Dorman/Gear_Shift_Repair_Kit/RB83242.html
  15. Blanco
    Blanco In Overdrive
    Los Angeles
    Because its been 110 degrees out everyday & the weathergirl says it will stay that week through the end of the week.
    I dont do to well in the heat.
    LOL!
    Thanks man your good at this, I'm assuming you've been through finding parts for these older cars a bit longer than myself..
    Thanks again. :eek:
    You da BOMB!
  16. Blanco
    Blanco In Overdrive
    Los Angeles
  17. Lord Snow
    Lord Snow In Fourth Gear
    Nashville, TN
    Just remember to bookmark any site you've bought parts from, or think you might buy from. That way you can easily find them when you do need something or finally get the money.
  18. Blanco
    Blanco In Overdrive
    Los Angeles
    I keep all receipts in a file for each car.
    & yes I bookmark.
  19. Blanco
    Blanco In Overdrive
    Los Angeles
  20. 5.0 Chero
    is yours a manual shift if so I have a nos factory ford collar I will sell you for $60 shipped.
    The links I have been sending you are fer automatic trannys
    with manual transmission
    and column shift;
