C4 Automatic Transmission linkage (column shift)
Discussion in 'General Ranchero Help' started by Buds 67, Nov 12, 2025.
  1. Buds 67
    Buds 67 In Fourth Gear
    Rome, Georgia
    When the headers were installed on my 1967 Ford Ranchero Fairlane 500 they did a crappie job and I'd like to do it better. I need a picture or diagram of the part that bolts to the frame because it's not right, it's tack welded there. Also if that part is available? Thanks
  2. pmrphil
    Howdy Bud -
    Not quite sure what you're looking for - my 67 with C4/column shift had no attachment to the "frame", it went from the column directly to the transmission arm. I ended up installing an AOD trans and used Lokar linkage for the column to trans and Lokar cable for the passing gear. The only welded on part I recall was the power steering ram mount had to be lowered to clear the headers and mine was "hacked" by the previous owner as well. There used to be a bracket available to bolt on where the original one did, but rarely see one anymore.
    Buds 67 likes this.
  3. Buds 67
    Rome, Georgia
    Thanks pmrphil, I was told that it was attached to the frame (I don't know) he also said that some did attach to the frame and some didn't ? Again (I don't know) what I do know a previous owner "hacked" the hell out of it, the part not attached to the transmission is NOT original, and that's the part I need to FIND! It's a homemade part there now! I want to get it as right as I can!!! The info you gave he helps and thank you for helping!
  4. beerbelly
    Could you post some photos? That might help.
    pmrphil and Buds 67 like this.
  5. Buds 67
    Rome, Georgia
    I can't today I'm out of town, but if your talking about a picture of what's there now, I'm not sure it would help because what's there now is not original, you can tell it's be fabricated I do know if I had a photo of what's supposed to be there that would help me!
  6. pmrphil
    It would help a BUNCH, as it would show what it's attached to. Mine was also not the original linkage, but I was able to make it work - BUT, it was NOT attached anywhere but from the column to the shift arm on the transmission.
    So, yes, pictures will help.
    Buds 67 likes this.
  7. Buds 67
    Rome, Georgia
    Thanks
