Camber adjustment
Discussion in 'General Ranchero Help' started by Gregory Cummings, Dec 22, 2019.
  1. Gregory Cummings
    Oceanside, CA
    On my '79 Chero, 351/400M 2V
    I need to adjust my camber
    or is it canter. anyway, the top side of my tires are a little bit more (in) than the bottom side of my tires. I need to know how to adjust the camber/canter so my tires up are straight up and down. All help is greatly appreciate it thank you.
  2. 5.0 Chero
    Needs to be done on am alignment machine But the upper control arms are adjustable for both caster and camber through the bolts that mount the crossbar to the frame.
    Yup, alignment machine, and also, the toe is part of the deal.
  4. The Wrench
    The Wrench In Second Gear
    If you haven't already checked the upper control bushings for wear you should. As the rubber in the bushings wear, the top of the tire will lean in towards the engine with a camber change and possible caster change and toe also. If the bushings are fine then have an alignment performed on vehicle. The Wrench
  5. RancheroRandy
    RancheroRandy In Overdrive
    OK, I'm sure I'll get some feedback but I've always relied on the accuracy of my eye plus the use of a straight edge...alignment has never been much of a "mystery" and understanding how things work (or should) is key in setting your frontend up....just sayin'....
    Hillbilly likes this.
  6. Hillbilly
    Been doing my own line ups for years too. A little bit of logic and a super flat floor raised up just right so I can step back and eyeball the wheels at eye level work perfectly for me. Didn't take long to figure out how to do it.
    RancheroRandy likes this.
  7. Gregory Cummings
    Oceanside, CA
    OK THX.
  8. Gregory Cummings
    Oceanside, CA
    THX
  9. Gregory Cummings
    Oceanside, CA
    OK THX
  10. Gregory Cummings
    Oceanside, CA
    He did. THX Carl.
  11. Gregory Cummings
    Oceanside, CA
    Good reply THX
  12. Gregory Cummings
    Oceanside, CA
    Good one RR, U're like me.
