Can’t believe it happened
Discussion in 'General Ranchero Help' started by Saff54, Jul 18, 2026.
  1. Saff54
    Hey guys,been a while since I’ve been on the forum,been so busy,last week finally had a chance to take out my Chero,been running great,so….driving in a parking lot when I heard a giant clang in the motor,pull over and smoke is coming from everywhere,when I get out of the car I realize it’s not smoke but antifreeze coming out of the dual exhaust,dripping from the bell housing ,open the hood and the air cleaner is tilting to the side and the wingnut is gone,pull off the air cleaner and the stud that screws into the sniper2 is also gone,the stud and wingnut snapped off and dropped into the motor,what the heck is the chance of that happening? I’m sick to my stomach over this,had it towed to my garage,pulled the plugs and the plug on drivers side closest to the firewall is bent,getting a camera on Monday to feed into the plug hole to see what damage it did,hoping it’s just the top end of the motor and having the heads re-done but expecting the worst once I can look in there,ever heard of that happening? IMG_5181.jpeg
    Lincolnut likes this.
  2. pmrphil
    Oof. Not good. Unfortunately, coolant coming out the exhaust usually means there's a crack somewhere, either a head from squishing the nut/stud there, or worse, a crack in a cylinder bore, caused by the piston "rocking" when the object in the bore stops the piston travel on one side, cocking the piston hard. If it cracked a bore, a sleeve will normally fix it, they're WAY stronger than most people will ever know. Good luck.
    The Wrench and Lincolnut like this.
  3. Saff54
    Thanks for your response Phil,got the camera in there and you can clearly see the stud,piston and cylinder wall looks good,top of the piston is a little beat up but no holes or cracks,I have another set of matching heads C7AE if indeed the head is cracked but don’t know of any shops I can send them to,Phil we live in the same area,do you have any shops you could recommend?as always thanks for any help you can send my way
