Center caps from 1973 slot mags
Discussion in 'Ranchero Parts Wanted' started by Boiler92, Nov 20, 2022.
  1. Boiler92
    Indiana
    I picked up a set of 1973 Ford factory aluminum slot mag wheels with Mustang center caps. Apparently you could order these wheel for other models with this type of cap.
    Need a set of 4 or at least the center emblem inserts. They look like this:
  2. 1978GT
  3. Boiler92
    Indiana
  4. 5.0 Chero
  5. Boiler92
    Indiana
  6. Boiler92
    Indiana
    Yeah, I just found another one like that and it says 2.5" diameter. The ones I need are 1-3/4 to maybe 1-13/16".
  7. beerbelly
    I'm confused- are those your center caps you're showing, or are those the inserts you need? Were there Ranchero-specific inserts?
  8. Boiler92
    Indiana
    I have the same caps only with Mustang inserts. I don't want to put Mustang caps on the Ranchero.
    Here they are after I popped out the emblems:
  9. Boiler92
    Indiana
  10. 5.0 Chero
    1968 Rio Grande wheel centers
    https://www.ebay.com/itm/134189725002
  11. Boiler92
    Indiana
    Those actually look like they would work, BUT he only has 3 left at $150 each. That's way more than I gave for the wheels, lol.
  12. 1978GT
    Boiler92 likes this.
  13. Boiler92
    Indiana
    Started polishing them up today.
    Kiwirancher likes this.
  14. Monk Daveohue
    Monk Daveohue In Second Gear
    Southern California
    That is great work.
    Except on the outer edge near the rim, I have trouble polishing that type by hand because of all the holes. I usually use mothers, but sometime have to start with wet and dry emery paper.
    Are you using a foam ball or cotton wheel? What compound.
    What size are they ? 14 x6?
  15. Boiler92
    Indiana
    14x6, yes. I cleaned the wheel with Mcguire's aluminum wheels cleaner first which was no more effective than soap and water.
    Using a rag and Mother's compound. I tried the Mother's foam cone but it wasn't working any better or faster than just using a rag and hand polishing. Here's a short video on it:
  16. Garbageman
    Garbageman In Overdrive
    SW Washington
  17. beerbelly
    Boiler, if you're interested in them but the guy won't ship them, I can pick them up & ship them for you; less than 10 miles from me. PM me if you'd like.
  18. Boiler92
    Indiana
    Thanks BB but your stickers look great and I don't think those inserts are the right diameter anyway.
  19. beerbelly
