Changing Rear Seal on C4
Discussion in 'Ranchero Tech Help' started by colnago, Jun 12, 2019.
  1. colnago
    colnago In Overdrive
    Ridgecrest, CA
    The C4 I have in my '64 is leaking out the rear seal. Can I change this without removing the tranny from the Ranchero? I assume I'll have to remove the yoke or U-joint at the end. What else will I have to do? I'll probably make some phone calls to the local tranny shops, just because it would be a lot easier to write a check than it would be to play with this in the driveway.
    When you say 'rear seal,' do you refer to the yoke seal, or to the tailshaft housing seal? If you refer to the yoke seal, no, it can be done in-car, just by removing the driveshaft. You'll need to make matchmarks on the pinion yoke to the u-joint. Then carefully pry out the old seal, use a big deep socket to tap the new one in, make sure it's straight, and clean/lube the yoke's slip shaft with frest ATF and install.
    colnago likes this.
  3. ForistellFord
    Beautiful Foristell Missouri
    Don't lost the spring that's in the seal though. Hey, it can happen.
  4. colnago
    Ridgecrest, CA
    Yes, I'm talking about the yoke seal. Do I disconnect the driveshaft from the rear end, then slide it off of the tranny output shaft? I'll have to pull my books out tonight, to see what I'm looking at. Also, should I put silicone around the outside of the new seal, to prevent leaks between the seal and the housing? Good to know that I can do it in the driveway, though.
  5. 1965 Ranchero 66G
    No silicone the new seal will have a coating on it that looks like paint and it is a tight fit. Yes remove the driveshaft and use a clean catch pan, you will lose some fluid so keep the rear end up as much as is safe. Hardest part is removing the driveshaft, very simple task.
    Skip
    colnago likes this.
  6. TestDummy
    Doesn't hurt to get some fine emery cloth and polish up the driveshaft yoke before stuffing it back in there. Also good time to check the u-joints.
    Easier than trying your shoes. You got this
    ForistellFord and TestDummy like this.
  8. 1965 Ranchero 66G
    Good point but also ck the fit on the yoke with the new seal, if to loose they are adjustable, I would be happy to share how. Very simple.
  9. colnago
    Ridgecrest, CA
    Ummm ... I doubt it, but thanks for the vote of confidence. ;)
    handy_andy_cv64 likes this.
  10. TestDummy
    Adjustable, how? By putting in a smaller seal?
  11. 1965 Ranchero 66G
    Take the spring off of the seal, find the joint where it connects together it will unscrew then cut off a small piece off the flat side and screw it back together put it back on the seal and test for fit by sliding it on the yoke. I've done it many times on my tractor and a couple of cars.
    uk ranchero likes this.
  12. colnago
    Ridgecrest, CA
    That's a cool tip. I would have never thought about doing something like that.
  13. TestDummy
    Are you making that up? I've never done that. But to be fair, I've never had a reason to try doing that.
  14. 1965 Ranchero 66G
    Absolute truth, first time was on my tractor the seal I got was right OD but a little loose ID, it's been on there for over 10 yrs without even a seep.
  15. TestDummy
    Tractor I believe. A $4 seal from Advance Auto, on the other hand.
  16. 1965 Ranchero 66G
    Works in a pinch.
    The seals for cars are not made for any adjustment, but I'm willing to bet the one for the tractor was made for the fact that getting a replacement seal took a week at that time, and so an adjustable one was called for.
  18. handy_andy_cv64
    Anyway, the seal's easy to do. Just make sure you drive it in evenly, and make sure you get the one that has the outer extension rubber to protect the slip yoke from dirt.
  19. 1965 Ranchero 66G
    The one I did worked fine.
  20. 1965 Ranchero 66G
    I was not suggesting that he do that to his new ones are readily available, just passing on some tip's.
