Cheap door panels
Discussion in 'Ranchero Pics' started by beerbelly, Aug 31, 2019.
  1. beerbelly
    I had replaced my original warpy, rotten doors panels a while back with some masonite panels rattle-canned black, because, well, I'm a cheapskate who likes making stuff. But even I got sick of the crappy look, so I shopped around to get estimates on having a nice set made (Thanks for getting back to me Huevos!).
    Too spendy for this retired guy. Mac's has factory reproductions for $170, but where's the challenge in that?
    So I made a couple out of 3/32" black textured ABS plastic. They'll be fine for my daily driver Ranchero, and they still satisfy the 'cheapskate, makin' stuff' idea, at $26 for the material.
    P.S. That's a chunk of black foam I velcro'd on the window crank. My knee hits exactly on the sharp edges of that thing, so that's another cheapskate fix.
    new 3:32" ABS door panels .JPG
  2. Huevos
    Looks Pretty Good.
    pmrphil and beerbelly like this.
  3. HuevosRanchero
    looks great!
  4. 65restomod
    Nice look, now I understand about the foam on the window crank.
    Some how I pictured a big block of foam stuck to the handle and thought to myself that may look weird
  5. colnago
    Where did you get the ABS? I need to redo the headliner for my '67 F250, and a sheet of white ABS would be a big step up from Masonite painted with a can of Krylon.
  6. beerbelly
    I bought mine locally at a plastics supplier; I'm sure there are plenty of them in CA. It comes as thin as .060", which should be pretty flexible, and it can be heated and formed with a heat gun.
    P.S. My crappy original door panels had this emblem attached, but the repros I've seen don't include it. Does anyone else have these on their original panels? I might just transfer them over to the ones I just made.
  7. Huevos
    That's a Falcon emblem. Was your interior originally Black?
  8. Huevos
  9. beerbelly
    Yep.
  10. colnago
    Well, I priced out a sheet that was 42" x 72" (a SWAG on the size I would need for a headliner), and 0.177" thick (a hair under BeerBelly's 3/16"). It came out to $125. I assume that includes shipping, and that the majority of that price is the shipping. But maybe I'll look at something else …
    On edit, you should move the Falcon emblems over.
  11. beerbelly
    Almost 4' x 6' for a headliner? Seems big to me. And I used 3/32", about half the thickness of .177. I got my two pieces, cut to size, for $26 locally. Shipping of course would be additional, but I'd ask for a quote for a thinner material, cut to a more exact size, plus shipping.
  12. colnago
    Yeah, I was at work and just took a SWAG to give me a ballpark price. I tried to go smaller, and their quote system still gave me the same price, so I figured I had gone over some magic threshold.
    Oh, I see now where you specified 3/32". I had remembered 3/16", so that's what I aimed for. I'll play around with their system, and see if I can get something closer to my price range. Maybe I'll even take a few measurements of my truck!
  13. colnago
    I just went back to interstateplastics.com, and used a thickness of 0.093". That cut the price down to $66, even for my oversized sheet! That probably means that the thinner material is flexible enough to roll up, and ship in a tube or small box, rather than one big honkin' sheet.
  14. Huevos
    Don't go too thin, it will warp and won't lay flat.
  15. colnago
    Well, it doesn't matter. Even though it will roll up, interstateplastics is still putting a freight charge of $250 on top (shipping in to a residence, which has no loading/unloading dock :rolleyes:). It's not worth $300+. Yes, I can probably (possibly?) get that charge knocked off, if I called them, but I'll just go back to Masonite and Krylon. If I want the real deal, I can get it for $128, delivered, from LMC Truck.
  16. 65restomod
    Imagine the headliner sag after a hot day in the So.Cal sun
  17. Huevos
  18. colnago
    On my F250, there's a screw with a big head that goes through the center of the headliner, and snugs it to the top of the cab. It could still sag, but it won't be one big piece of unsupported fiberboard/ABS/Masonite/etc sagging.
  19. ForistellFord
    Beautiful Foristell Missouri
    That beast is going to re-sale for a mint!!! I kid because I care.
    Nice DIY, always appreciate homemade innovation.
    beerbelly likes this.
  20. beerbelly
    I'm pretty sure it will be on the grounds at Pebble Beach before long!
