Clutch disc snooker!
Discussion in 'Ranchero Tech Help' started by Dark Side Tom, Jan 27, 2019.
  1. Dark Side Tom
    Dark Side Tom In Second Gear BRONZE MEMBER
    Put in the new clutch and bell.
    Could NOT get the trans to go in!
    Got suspicious of the plastic pilot tool, as compared to the trans input shaft. Both were 1 1/16 wide, 10 tooth.
    BUT, the splines on the plastic tool (and the disc when I took it out!), were symmetrical in peaks and valleys, while the trans input has wider peaks and narrower valleys!
    WRONG DISC! See the pics. Note the plastic pilot versus the trans input.
    Anyone know why my clutch kit, which purports to be correct for a '64 Ranchero with 260 and T10 trans, doesn't fit??
    Maybe the disc (10") for a six??
    See the pics if clear enough.
    DST
  2. pmrphil
    I imagine you tried the disc on the shaft after you pulled the trans ? Kinda unusual for a coarse spline disc to not fit. Check the diameter of the shaft, then the disc, plus the measured width of the splines. It's not uncommon to have to fight with them getting them to mate up, not much room for error.
  3. Dark Side Tom
    No chance to fit! Would'nt go on the trans with a sledge hammer!
  4. LSChero
    Maybe later year T-10 or top loader? Any casting/tag numbers on tranny to ID?
  5. Dark Side Tom
    Not a top loader. Early T10 with narrow bell bolt pattern, wide ratio with 2.73 first gear on a 5 bolt bell. Gone on '65 model year. DST
  6. Dark Side Tom
    Got another 10" disc coming. Pick looks right, with wider peaks and narrower valley grooves. Will post if it slides on the trans OR NOT!
    That's why I always check the disc against the input shaft before an install; you just never know what you'll run into.
  8. Dark Side Tom
    Yeah, dumbass on my part!
    Why do you think I now do that? And it was a super T-10, aluminum case, my @$$! We strained our milk attempting to get it to go on, then my boss tells me to pull it apart, see if the disc goes on the shaft. Then he said, "You should've done that before." So, we've all been there.
  10. Dark Side Tom
    Disc came today! Fits perfectly! AUTOZONE #D4184. Will post a pic when I shrink its size at home. Too big to post.
  11. Hillbilly
    Don't feel too bad about getting had by that zinger. I think nearly all of us here learned that "Trust but Verify" lesson the hard way. Hope the rest of the job goes easy.
  12. Dark Side Tom
    Compressed the image. Clutch disc I got today.
    I know it's on backwards! Will install correctly...
    DST
  13. Dark Side Tom
    Finally got more than single digit weather! No heat in my garage. Had a heat wave today: 30F.
    Got my clutch, P/P, bell, and trans installed!
    Took some wiggling but went right in.
    So relieved!
    DST
  14. 72GTVA
    Good to read it is back together. Hate it when the gozinta doesn't fit the first time.
  15. TestDummy
    I bought digital calipers for that very reason.
  16. Basstrix
    Only 71 here today but able to hang in the garage in short sleeves.
    I'm a cheap bastard. That way, I don't have to overthink it.
    PonyExpressRider likes this.
